Grainofsand
How do I change the PTM modes on a car without the special steering wheel that comes with the PTM knob?
PTM is for Track mode only. It’s all laid out in the V-Series Convenience & Personalization Guide.I noticed that I cannot change PTM in my mode, tour, sport, snow/ice.
In V mode or track mode, push the traction control button twice and the menu should pop up for PTM. Then you should be able to use your mode up and down buttons by the shifter to change the PTM mode. I noticed that I cannot change PTM in my mode, tour, sport, snow/ice.
Is this the same for everyone?
Does someone have a better procedure for accessing this menu without PTM on the steering wheel?
No, PTM is also available in V-Mode. You have to configure which PTM setting you want in the V-Mode edit setting, and then double-press the V button to access it.PTM is for Track mode only. It’s all laid out in the V-Series Convenience & Personalization Guide.
Of course, that’s what I use mostly. But when the PTM slider is moved to the right the car goes into Track mode. When the Engine/Shift slider is above the first setting that is effectively Track mode.No, PTM is also available in V-Mode. You have to configure which PTM setting you want in the V-Mode edit setting, and then double-press the V button to access it.
