1Evil55
Not sure if you're following the example I'm making. I'm wondering if the builder in question was operating from a bad batch/lot from an outside supplier. I'd like to assume that Caddy could backtrack every part from each car by production run. When those parts show up for new builds are they distributed by batch to each builder or are the builders just coming and grabbing their parts off a communal table? I agree that if just one builder has the majority of failures that the common denominator is the builder obviously. Giving that individual the benefit of the doubt, is the same issue happening on multiple motors? Then could you track it back to bad parts from the supplier? Maybe his training for build wasn't good enough. What are the chances the same builder could have used faulty parts that were deemed good from QC but different areas of the motor from one build to the other. I guess I just want to give the builders a chance to keep their positions. I am eager to hear and learn more about this broke back motor.If the faulty parts are being distributed to ALL the builders , then it will show failures at each station. If just ONE builder is having the MAJORITY of failures, then there is a problem with that builder. Part failures are traced back to the manufacturer.....if the part fails because , let's say, improper installation, then that is on the builder.
