Blown engine
Well, yeah, now that we have the part numbers...
I had no doubt before the part numbers. That dealership would have been in a lot of trouble if they installed the wrong long block. They aren't that incompetent.
I won’t say that about dealers you might want to check to see how all your wires are routed correctly andif the clips are all connected not brokeas I just spent this morning, correcting mine. Hopefully you got a better job than I did..
My dealer hasn't touched my car yet, but Im quite certain no dealer is going to install the wrong engine.
So since i feel like the break in the advisor told me wasn’t correct (he said “just drive it chill for 500 miles then u can rip it”) and i asked him if i should get a oil change at 500 miles and he said no not till like 5k miles ??!? Like im pretty sure the break in is 500 miles then oil change then still baby it till 1500 then it’s good , what has other people who got the engine replacements advisors tell them
Your advisor is correct. Cadillacs don’t require an early oil change—the first one is scheduled at around 5,000 miles. The 500-mile oil change was specific to the LT1 and LT4 engines in the C7 Corvettes with the dry sump oiling system. That system was more complex and carried a higher risk of break-in debris staying in circulation, which could lead to engine damage. The Camaro and Cadillac, with their wet sump systems, don’t have that issue.
That said, you can certainly do an earlier oil change if it gives you peace of mind, but it won’t make a meaningful difference in engine longevity compared to waiting until 5,000 miles.
I'm assuming same applies to the diff and transmission oils?
I was planning to do something like that when I get mine, drain and fill all the mechanical oils after break-in.
Thank you!!! What do you think about the break in he said only 500 miles
The owners manual says 1500, so believe who you will. An early oil change (~1k miles or less) is always a good idea to flush out break-in particles.
I'm only going to say this one last time. Your work order only shows 8 quarts of Mobil 1 oil. CT5-V BW's take 9 quarts.
Have you checked your oil yet?
The whole 500 miles thing has caused HUGE confusion. First, READ THE BOOK. Tons of great info in there. The 500 is for the reduced RPM's only....that's it. 1500 miles is for everything else. Oil change is one year, or when the DIC says, or 10,000 miles. There is a mention of rear diff change if you're going to track it.
This horse has been beaten so many times. I'm sure a search will show the threads.
Anything you do above and beyond is up to you.
Use the book as a reference. At the very least change the oil filter at 500 and 1500 miles to help protect your investment and consider cutting open the filters and inspecting them.
@rubberduck .....Yeah, I know. I'm one of those old time wackos that actually reads the book. But, there really is a lot of good stuff in there!
And it’s really easy to search the PDF. 😎 I didn’t want to say what I really think, but on a Jeep forum such an oil question would result in harsh mockery. But, we don’t do that here because we are so much more sophisticated.
I do read it, but at the same time manufacturers are also known for doing sh*t like recommending year old oil changes (looking at you, BMW)... so it's really just seeking a second opinion.
Curious of your other "at the very least" items?
motor at 500 & 1500, rear diff at 500 is my plan and will be cutting the filter open just for the heck of it - why not take a look... If it looks sparkly I'll save it for the record. I might even save some of the oil - eghads, the OCD. Or maybe I'll not cut the 500 mile filter, save it, and cut the 1500 instead.
I have a Blackstone oil analysis kit too but not sure when I'll use it. Also Gold Plugs everywhere!🔩:happyanim:🔩 - that's probably going overboard! but, why not take a look. Plugs for motor, rear, TR-6060. Never bought a magnetic plug in my life so it's a trial run.
Yeah - I left off magnetic oil plug as well. I don’t know if anyone makes a magnetic plug for these vehiclles and the type of oil plug they have.
The 500-mile break-in isn’t just a random number. That first phase is mainly to let the bearings properly polish and seat.
If you watch the Chevy MyWay video on the Z06 LT6 (link here), the engineers go into detail on how the break-in works and why it’s critical. Even though the video is about the LT6, the same principles apply to the LT4.
Bottom line:
  • 0–500 miles → Vary RPMs, no full-throttle pulls, avoid high sustained speeds.
  • 500+ miles → Normal spirited street driving is fine.
  • 1,500 miles → Minimum before any track use. By then, bearings, rings, trans, and diff are all fully settled.
So yeah, 500 miles gets you through the initial break-in for street use, but the 1,500-mile requirement is still there if you plan to track the car.
Bottom line:
This post needs to be sticked for all future users to reference.
