burn813
Original Ginger
- Joined
- Jun 14, 2021
- Messages
- 859
- Location
- St. Louis Missouri
- V-Series Cadillac(s)?
- 2022 CT5-V Blackwing
lol oof
Let Me Google That
For all those people that find it more convenient to bother you with their question than to google it for themselves.letmegooglethat.com
Edit: Meant to be funny, not rude.
Amazing. Glad it is back with you.Car is FINALLY back after nearly 3 months with not only a new long block, but a new gas tank and much, much more. It sounds like what happened was the evap canister or something else with gas tank emissions filled up with fuel & that was causing the ecu to think everything was running rich & leaned things out to the point where it fried an entire bank of spark plugs and caused the rings to stop sealing well. The supercharger was then pushing pressure into the crankcase leading to blown out seals.
Bottom line is original engine didn’t fail, rather something else happened that caused the engine to fail. Makes me kind of wonder if this is also what happened with the car and driver long term tester engine. It definitely sounds similar.
Good to see your whip is back!Car is FINALLY back after nearly 3 months with not only a new long block, but a new gas tank and much, much more. It sounds like what happened was the evap canister or something else with gas tank emissions filled up with fuel & that was causing the ecu to think everything was running rich & leaned things out to the point where it fried an entire bank of spark plugs and caused the rings to stop sealing well. The supercharger was then pushing pressure into the crankcase leading to blown out seals.
just in time to sit in the garage for the 3 inches of snow that's about to hit! but seriously i am glad it isn't sitting around the dealers anymore. it's definitely much safer sitting in my garage vs thereGood to see your whip is back!
GM engineering I know wanted everything that came off my car sent to them and wanted a LOT of data collected on the car. That delayed by several weeks me getting it back.Interesting (positive regarding the LT4) outcome @Carguyshu
Another potential clue for the reason there are so many built 4x00 holds?
Tough part about this is it’s so random. It’s not like spring mt is blowing up BWs left and right with the driving school. This forum doesn’t represent majority of BWs but the amt of engine issues popping up just here seems high even if it’s 2-3 engines since it’s a low production car. Just look at the S55 bmw engine. The production of that engine and the amt of spung bearings probably is a lower percent than what we are hearing of BW but even low percent can cause a lot of drama. If they identify the potential flaw, hope it’s an easy fix and we aren’t all out a BW for weeks while a mix bag of dealers try to address the recall.GM engineering I know wanted everything that came off my car sent to them and wanted a LOT of data collected on the car. That delayed by several weeks me getting it back.
if it's a flaw its one in the fuel and/or emissions systems and not the engine itself.Tough part about this is it’s so random. It’s not like spring mt is blowing up BWs left and right with the driving school. This forum doesn’t represent majority of BWs but the amt of engine issues popping up just here seems high even if it’s 2-3 engines since it’s a low production car. Just look at the S55 bmw engine. The production of that engine and the amt of spung bearings probably is a lower percent than what we are hearing of BW but even low percent can cause a lot of drama. If they identify the potential flaw, hope it’s an easy fix and we aren’t all out a BW for weeks while a mix bag of dealers try to address the recall.
Glad you got her back, gotta make up for lost time my friend! Enjoy!Car is FINALLY back after nearly 3 months with not only a new long block, but a new gas tank and much, much more. It sounds like what happened was the evap canister or something else with gas tank emissions filled up with fuel & that was causing the ecu to think everything was running rich & leaned things out to the point where it fried an entire bank of spark plugs and caused the rings to stop sealing well. The supercharger was then pushing pressure into the crankcase leading to blown out seals.
Congrats on getting it back and for getting a straight answer about cause of failure. Wonder who along the chain could've possibly overfilled tank to point of filling vent hose, evap canister. 288 miles doesn't really give too many opportunities.just in time to sit in the garage for the 3 inches of snow that's about to hit! but seriously i am glad it isn't sitting around the dealers anymore. it's definitely much safer sitting in my garage vs there
My car is different from original poster’s problems. My car had roughly 3,600 miles on it when this all happened including several track days. I’m the only one that has filled the tank since it was new (the car arrived near empty on gas when it was shipped to me) and have never overfilled it. I got black flagged at the track for smoke coming off the car from the oil leaks dumping oil on the exhaust. It still ran surprisingly well with leaky cylinders & toasted plugs as getting flagged is what caused me to notice & not a drop in performance.Congrats on getting it back and for getting a straight answer about cause of failure. Wonder who along the chain could've possibly overfilled tank to point of filling vent hose, evap canister. 288 miles doesn't really give too many opportunities.
@Carguyshu I think we both just got the short end of the stick regarding it. I've seen more issues with the fueling than my crankshaft issues.Congrats on getting it back and for getting a straight answer about cause of failure. Wonder who along the chain could've possibly overfilled tank to point of filling vent hose, evap canister. 288 miles doesn't really give too many opportunities.
Oops, I'm old, tired and need my rest. That what is sticking with. You guys are all starting to look alike.@Carguyshu I think we both just got the short end of the stick regarding it. I've seen more issues with the fueling than my crankshaft issues.
@OldGoat I was the one who suffered the 288 mi failure. Mine was a manufacturing defect in the crankshaft. I have a 2023 and Shu has a 2022.
I just got my car back after 2 months and no, it isn't fixed. But I did get an extensive writeup on what they checked and replaced (a lot!). It is apparent that the GM engineer they sent to try and figure out what was wrong was familiar with your situation, I was a little confused by their checking the evap canister for fuel and doing compression checks on the cylinders but it now makes sense. And replacing all the supercharger seals.Car is FINALLY back after nearly 3 months with not only a new long block, but a new gas tank and much, much more. It sounds like what happened was the evap canister or something else with gas tank emissions filled up with fuel & that was causing the ecu to think everything was running rich & leaned things out to the point where it fried an entire bank of spark plugs and caused the rings to stop sealing well. The supercharger was then pushing pressure into the crankcase leading to blown out seals.
