M2Cto4BW
Agreed. I had about 3 gallons left when it came on for meFWIW, on my 4BW the low fuel warning came on at around 30 miles remaining. When I went to fill up it appears I had about 2 gallons left.
Do different engine levels (tour, sport, track) impact the amount of cooling that turns on?
I didn't see anything in the manual saying as such and maybe the car is smart enough to turn it on as needed regardless of mode?
Asking as with the M2C, when in Sport+ the fans would engage much earlier/by default be on, compared to Comfort and Sport.
Per the owner's manual:I can't figure out what engine/shift does
Per the owner's manual:or why it is missing from My Mode
That's for the BWs with training wheelsPer the owner's manual:
Transmission Shift Mode
Sport or Track – Dynamic Performance Mode (DPM) allows the transmission to hold the current gear after a quick release of a heavily applied accelerator pedal. This provides greater engine braking and enhanced vehicle control without using the paddles. DPM recognizes aggressive cornering, heavy braking, and high acceleration to select and hold lower gears when not using paddles. The shifts are also firmer to increase the quickness of shifting.
Transmission tuning...meaning whether or not it was arm day at the gym?Per the owner's manual:
My Mode
My Mode is used to personalize everyday driving. This mode is designed to allow the driver to configure vehicle systems to their own preference for city or normal driving.
The stuff I highlighted in red shows that the transmission tuning is for sporty driving, and My Mode is for non-sporty driving.
Holding gears doesn't apply to manuals.
That's why I specified my question was about the 6MT...I assumed that it altered shift points on the 10A, but I couldn't tell any difference on the 6MT.
The manual looks like it has "Engine/Shift" labeled as "Powertrain". It says that option actually controls 3 things:
"Powertrain adjusts the throttle response, gear shifting and engine performance."
"Engine performance" is pretty vague, and "gear shifting" likely does not apply to a manual. But I would expect the "throttle response" to apply. Do you notice anything with throttle progression when you adjust Engine/Shift?
Isn't that when a green gear shows up on the screen?Per the owner's manual:
My Mode
That happened on my 2020 CT5-V sometimes...Isn't that when a green gear shows up on the screen?
Ah man how the hell have you not customized the crap oot of that yetI just realized that I can adjust that independently in V mode (it is labeled as "engine/shift" in my car). Now I have something to mess with on my way home. Will report back.
I've used the "Transmission Shift Mode" many times and its great.Per the owner's manual:
My Mode
I've customized it somewhat, same as you except I also set steering to middle along with suspension. Haven't messed around with PTM, I'm saving that for after break-in.Ah man how the hell have you not customized the crap oot of that yet
You can also set the PTM in there which is cool.
TBF I basically turned it into another Track Mode, but with Suspension in the middle and PTM set to Dry.
Ofc! Still early doors for you.I've customized it somewhat, same as you except I also set steering to middle along with suspension. Haven't messed around with PTM, I'm saving that for after break-in.
Always DOUBLE tap. Otherwise PTM is neutered and the car only goes straight. These cars are much more fun when going sideways!Do you guys use the double tap on V Button?
I don't understand, I thought you could tap V button twice and it will send the car to the PTM pre-selected? Did I read that wrong n the manual? Thats what we did at SM...I guess I'm lost..I dont tap. Scott from tap out said dont do it. My V mode has not PTM since the PTM switch is right there and I can get into it no matter what mode. It also makes exiting out of it easier.
No your right. But how do you exit? With no PTM set up in V mode you can use the PTM switch on wheel to get PTM and out, "inactive" but also exit V mode with one click vs the TC button. The choice is yours hence the different ways.I don't understand, I thought you could tap V button twice and it will send the car to the PTM pre-selected? Did I read that wrong n the manual? Thats what we did at SM...I guess I'm lost..
