Subwoofer Install
Does anyone have a solution for a fuse that can be used as a remote turn on. I don’t want to run a wire to the front of the car where I know I can find one... I’d like to keep it contained within the trunk
Lc2i for remote is what I used to keep everything together in the back.
Just wanted to share some of my install - Need to wrap the harnesses and tidy it up a bit (got some shorter RCA's coming) but overall I am happy. Now I just have to go through the interior and clean up all the vibrations from the new sub.. haha!
I got a smoking deal on the sub / box from Best Buy as an open box.. The box fits within 1/2 inch from the top of the trunk in the rearmost position.
I ended up clipping my 5BW ANC wires - with enough room to resolder them in the future.
I tapped into the right 6x9 for signal to my LC1i. Works fine.
Once its cleaned a bit more I think it'll be nice and presentable..
Looks really good. How are you going to secure the box so it doesn't shift around when you drive the BW as intended?
Will a set of golf clubs still fit?
Page 5 of this same thread
I ordered this one from LLJ and installed it over the weekend. It doesn't completely work. I noticed that sound inside the car was really muffled. With this bypass, my A-pillar tweeters are disconnected. Anyone had similar issues?
Contact LLJ directy. You may have plugged it in to the wrong slot, or they may have wired it incorrectly
Sadly LLJ is not up to snuff anymore. Several years ago they were on top of things. Lately it seems not so much. Good luck.
I have been emailing them. They said it should be the correct harness. I sent over pictures of everything. Waiting on response now.
If things don’t work out. Check out my thread on my enclosure build. I have a section showing how to disable ANC without the adaptor
I havent tried mine yet. Is the trunk lining easy to get out? Does yours look wired like this? Anyway, hoping yours somehow got miswired so they can get it sorted. The build on mine looks to be top quality.
Are there 4 total wires? If so, it's exactly the same. For the lining, you need to remove 4 plastic push pins. You can then bend the carpet enough to get to amp and bolts. There are 3 10mm bolts that hold the amp down.
yes, 4 wires. I'll give it a try and report back. Thaks for that and headsup on carpet & 10mm.
Did you get a chance to try it? I've been trying to get a hold of LLJ (no response to my last two emails). The last response was over a week ago. They said they would get with their techs.
Have not but will get working on it! Needs to be done, hopefully back by Sunday. I have no subwoofer plans, just want to defeat the ANC/piped in sounds.
ps. I wonder if texting them would get a quicker response? I think they texted me at one point with an eta on the harness and said to text them with anything else. (I did hit a lucky window with their backlog since it shipped within 3 weeks).
