Track Mode
Tried everything...two quick taps two deliberate taps...nothing works. My manual says competitive driving mode is not available in any of the settings..EDIT....I am reading that the tires need to be at a certain psi to enable Competitive Driving Mode? Mine are at 34 psi cold
Never mind figured it out ..I was trying to switch to sport from My mode and it didnt work. When I access Sport via mode button it worked
Now that is settled, don't be doing Mustang-driver things.
Joins Ford Mustang GIF
Double-tapping V-mode also fails to bring up the mode they used in Spring Mountain if you have suspension in the softest setting in your V-Mode settings.
Yes My Mode settings for me for daily driving was softest suspension ...then from My Mode I would put it in Sport going up two clicks with the ptm switch on steering wheel ...double tapping TC button from there did not work. When I got out of My Mode and then went to Sport the double tap worked.
Car dynoed 498 rwhp on heartbreaker Mustang dyno...the shop warned me....they told me a 580 HP cammed header straight pipe Z06 put down 430 on that dyno. 800 hp built Subarus put down 600 HP. The shop tuner said this was the best fuel curve he had seen on a factory tune. He did a dynojet conversion for me which was 628 rwhp.
Good thing I have absolutely no idea what you guys are talking about. I get in, push the start button and drive away. By the time I figure out some of the bells and whistles.....I park the car for 6 months during the winter and soon forget all the cool stuff that this car is capable of. I'm lucky if I can remember how to turn on my smartphone light.
