Subwoofer Install
The wiring diagram at the start of the thread (which I believe was stated to be CT5) is the same as this for the CT4, and shows the ANC connections.
There's a mention in another thread that the 4BW doesn't have ANC. Not sure if it's valid.
From the 2025 CT4 Owner's Manual:
I think the discussion you linked was about fake engine noise being used, not ANC. When we toured Corsa I asked how their exhaust worked with ANC, and they did say that ANC would not be as effective because it had different tones than stock. That was specifically discussing the 4 BW.
Makes sense. Either way, it sounds like disabling it is the best option.
I ran new ground to body and direct to battery. No change for me as for as the sound goes. It sounds like it is the pumped in sound and not ground noise though. When I turn gains down it is greatly reduced. Here’s what I have with a 12 inch sub. I’m at a loss at this point on what is going on
It looks like the harness might be the best option. Where did you tap into for high level audio?
I wish I could help, but I don't have the car yet. I have been researching the setup. It looks like there could be 3 options.
  1. Depin the ANC microphones (hard to find the tool).
  2. Check with LLJ customs to see if one of their bypass harnesses will work with the 4BW (probably the easiest).
  3. Possibly connect to the low level inputs that go into the amp. This is before the amp does any processing of ANC noise. Not sure if this actually works, just saw the suggestion on another forum.
I will give it a try. I can’t believe I’m the only one having this issue. Thanks for the troubleshooting tips.
Removed pin #3 so far, had to cut as could not get it to depin, and left other 2 intact with a few test drives ANC feedback in subs seems to be resolved.
If it any louder in cabin I can not really tell.
No one likes road noise but I don't mind exhaust, engine, SC noise at all so not a big deal to me. Every car before this that had a V8 (truck or Camaro) I actively tried to make those sounds louder any how.
If it any louder in cabin I can not really tell. No one likes road noise but I don't mind exhaust, engine, SC noise at all so not a big deal to me. Ever car before this that had a V8 (truck or Camaro) I actively tried to make those sounds louder any how.
Any idea what the 3 different mics control? Are they just different locations?
From what I understand yes, 2 in the front and 1 towards the rear. I have nothing to point too as hard fact on that its just what I have read and believe to be the case.
I don't know for sure which of the 3 wires goes to which mic. I just decided to start with #3 and see with the plan of doing all 3 if necessary.
Been month since I removed mic #3 from the equation still no issue and all sounds good. Here is what was installed as well.
Looks great. Did you disconnect the factory sub? it might be different on the 5BW (I have a 4BW).
Thank you. Im not an authority but I do not believe the 5BW uses what I would call a subwoofer. They have 6x9s in the rear deck that supplied the "bass". My subs are tapped from the rear 6x9s, which I disconnected, for their audio signal.
So I just got my sub installed today. I have a 10" sub, kicker 400w amp and used the LC2. I had the installer disconnect the factory sub and I did not use any anc bypass. He pulled the signal from the factory sub. Also had a bass knob installed.
I have no feedback from anc at all. I'm not sure if it's bc of the disconnect but I'm happy with the results. I now have bass at low volume compared to factory.
This is on a 4BW btw.
Just need to figure out how to secure the sub. I wasn't sure how I wanted it placed so they just placed the box flat as far back as possible. Amp and LC2 was mounted in the space below.
Good to know. If you get any feedback in the future, please update. Thanks.
Well it looks like it was short lived for me. I'm now getting feedback from the sub. It gets greatly reduced when I turn the kicker bass knob all the way down. The bass goes in and out as well.
LLJ seems to be dead. They won't answer calls or emails. Anyone know of another company that makes a bypass harness? I don't want to cut any wires especially if I remove the sub later down the road.
I will echo that LLJ whether alive or dead is no longer useful. I did use them around May of 2021 with great success but alas that seems to be the distant past. I'm not a proponent of online reviews but with the mass they achieved of the same issue, not shipping or refunding items, there is a major problem at their shop.
As for bypass there is no one that I found when looking and talking with my local shop. I will say cutting the wire is not necessary as you can have the harness depinned and achieve the same results. But cutting is a simple resplice fix if they need to be set back to factory.
