Track mode engine/throttle reponse dull
Sorry, I meant do you have a different ptm setting in each mode? I thought maybe that could be a reason for the difference you're perceiving
Oh no. PTM is inactive by default. I think you can only do a preset PTM in V mode, which I also have inactive.
Ohh okay. For me (CT4 BW) I can adjust/save the PTM setting in V mode or track mode in the center stack settings area.
I have V mode set to PTM dry so it enables launch control but doesn't push the suspension to full stiff
The Blackwing has two stability control and traction control systems - Traction Control System (TCS) and StabiliTrak/
Electronic Stability Control (ESC). SpringMountain had a session on this item and they also mentioned the linear versus non-linear throttle response is affected by the Driving Mode selected.
I think this is what you are looking for:
RACE 2
. For use by experienced drivers who are familiar with the track.
. Dry conditions only.
. Requires more driving skill than in other modes.
. StabiliTrak/ESC is off and engine power is available for maximum cornering speed.
In modes other than Race 2, the throttle is reduced when cornering - eLSD lock/unlock based on steering angle/and measured wheel slippage. So you if want to drift you need to be in Track/Race 2 mode.
