Orange Whip
Obviously not a BW, but a good overview of underfilling/removing:
Exactly and as I recall I checked the Tremec website and saw ATF there as well.Well, it certainly is ATF in the BW5 with the -6060.
And if you go to Redline and others to find what their equivalent product is...it's 'straight' ATF.
D4 ATF - Quart
- Our most versatile ATF, use where Dexron III®, Dexron II®, Mercon® and Mercon V® fluids are recommended, for use in automatic, manual transmissions and power steering
- Popular applications: Toyota Type T-III and T-IV, Honda ATF-Z1, Nissan Matic D, J & K, Diamond SP-II, SP-III, Mazda ATF M-V, most BMW and Audi/VW automatic transmissions
- Also used with manual transmissions and transaxles like T-5, T-45, T-56 and late-model BMW, provides a GL-4 level of gear protection
- Excellent cold weather operation
Of course. For me the essential part of the equation is: when you buy directly from TREMEC and they are responsible for the warranty, they recommend HP-MTF.I'm dubious on the whole "internet guy recommends this magic sauce" thing. OEM's spend millions validating fluids and just because Larry and his buddies all run some fluid cocktail without issue is not evidence of anything.
Here is the Tremec spec sheet where they call for ATFExactly and as I recall I checked the Tremec website and saw ATF there as well.
What is interesting (anecdotally, perhaps) is the manual transmission in the V6 6th Gen does not use Dexron and has a fill/drain procedure that is 'fill to the bottom of the fill port and call it done'. The M6 in the V6 is NOT a -6060.
Well, that is even more bizarre. So the -6060 in the BW4 says to run MTF, but the -6060 in the BW5 says to run Dexron?
TREMEC HP-MTF™ MANUAL TRANSMISSION FLUIDHere is the Tremec spec sheet where they call for ATF
this is what is SO frustrating and confusing. Your image in exerpt from the OWNER manual. My CT4 OWNER manual also says Dex III. But my excerpt is from the SERVICE manual which specifically calls out the gear oil. I am shocked by how inconsistent and bad the documentation is. How do we find out for sure - 75W85 gear oil and ATF are VERY different!Well, it certainly is ATF in the BW5 with the -6060.
D4 ATF - Quart
On the internet, everyone is a powertrain engineer! And if we're going to go down the cynical road and claim that Dex3 is a function of convenience and cost, I'll join you and suggest Tremec re-branded an existing cheap fluid to create a profit center peddling Tremec branded product. I don't believe either is true, just pointing out how easy it is to fabricate a narrative to support our biases.
Most cars on the road get the minimum recommended service using middling products and live very long lives. Following the OM and using factory fluids in our BW's, one can expect a very long service life as well. I over-service my cars and have my favorite fluids, but I do it because I enjoy the process and it satisfies my personality quirks.
Hi All,
First post - I am taking delivery of a 2024 CT4-V Blackwing on Wednesday. 6MT, Black on black, with performance seats and alcantara. I am beyond excited. I am joining the seemingly large group of ex-BMW folks who are choosing Blackwings over G80 M3s.
I've been preparing for my break in service and reading the forums, but one thing that seems notably absent is discussion on a fluid change for the 6MT. It's a bit strange to me that the OM recommends a diff fluid change before tracking but mentions nothing of a 6MT fluid change for break in. I am planning to do a 6MT change at 1500 miles along with the diff, but figured I would throw it out there to see anyone had thoughts or opinions. I figure it's easy and cheap, and what's the worst that can happen? Besides, I like being underneath cars almost as much as driving them.
