CT4-V 4BW issues the dealer can’t figure out
Cadillac CT4-V model
Does it only happen when you hit a bump or pothole? When you turn?
did they put it on a lift then try to grab the wheel and jostle it around to see if they can get it to make the noise? Check the rear cradle bushings and bolts?
Do you notice a performance issue? I retired from chasing mystery sounds a long time ago and recommend the same to others if you want to keep your hair.
Much easier to diagnose a performance issue and if there isnt a performance issue…. Is there really an issue?
