obeykube
- Joined
- Feb 13, 2024
- Messages
- 224
- Location
- Long Island, NY
- V-Series Cadillac(s)?
- 2024 Cadillac CT4-V Blackwing
Wondering the same thing^
I went with OEM spec 9.5” in the rear. I’m not sure if there is a difference in concave between the two. I’m not sure if this is verifiable from their website or not but if not someone at Apex I’m sure could answer.Did you go with the 9.5" or 10" rears? They look great. I'm torn between the Anthracite and Bronze Wheels for my black CT4BW.
I'm curious if the 10" wheels are more "concave" than the 9.5 or if it's just the same concavity, just a tad wider.
I thought Apex were hub-centric and didn't require centering rings?The gentleman you are looking for is Cory Smetzler @ Apex Support -- email is support@apexwheels.com
Extremely knowledgeable and very quick to respond -- here is the setup I went with
Can you post photos of your car with those weeks?. I found a post you placed on the "What did you do to your BW" thread but the pictures are very low res.The gentleman you are looking for is Cory Smetzler @ Apex Support -- email is support@apexwheels.com
Your car looks amazing! Thanks for sharing photos.I did not need spacers but Discount Tire told me the stock lug nuts would damage the paint on the wheel. I know prior posts said you can use the stock lugs but I didn’t want to risk it so bought some they had on hand.
For forged wheels where each one is machined from block of aluminum and designed around a particular application, the visual depth or concavity will vary. We have some wide, low offset wheels that typically would point to a really concave offering, but that spec of wheel has to clear motorsport level brake calipers, so the face is fairly flat to get around those brakes. Another example is we have a Mustang rear wheel and a Corvette rear wheel that are the same diameter, width, and offset, but the brake clearance is vastly different so each wheel has a different spoke profile.Wondering the same thing^
I'm happy with the satin black. I also considered the anthracite but thought it might be too close to the Shadow Metallic color and wanted some contrast, plus it matched the black trim. And we have bl4ck_wng with Shadow Metallic with silver for the trifecta.I went with Anthracite in OEM spec and mounted the stock tires. I will say the pictures don’t do these wheels justice in my opinion (not that they look bad in photos, just better in person). I initially ordered these in Satin Black then changed my mind to Anthracite and I’m glad I did. I think these show the depth/detail a bit better and some of that can be lost in the satin black. The wheels have some concave which I like. This is stock size but the rear looks like it pokes out just a bit more which I think was confirmed in prior posts due to offset. I did not need spacers but Discount Tire told me the stock lug nuts would damage the paint on the wheel. I know prior posts said you can use the stock lugs but I didn’t want to risk it so bought some they had on hand. I believe Apex marketed on the box these were shipped in “built to win races not shows” but these are the best looking wheels I have ever had on a vehicle. Very satisfied with these.
Some sizes are hub centric, some aren't. They're only there to help with initial installation though, once the lug nuts are torqued down the wheel becomes lug centric and the hub is not doing anything. Same way the factory wheels are setup.I thought Apex were hub-centric and didn't require centering rings?
Yikes you are right— idk what happened there. See (hopefully better) pics belowCan you post photos of your car with those weeks?. I found a post you placed on the "What did you do to your BW" thread but the pictures are very low res.
Nope, these are BMW setups, they fit our cars, but require adapter rings to retain the hub-centric fit.I thought Apex were hub-centric and didn't require centering rings?
Not true, the factory wheels are hub-centricSome sizes are hub centric, some aren't. They're only there to help with initial installation though, once the lug nuts are torqued down the wheel becomes lug centric and the hub is not doing anything. Same way the factory wheels are setup.
No, the holes are larger than OEM so the clips won't grip. The overall diameter of the cap is about the same though. I fabricated what are essentially adapters as described here: Questions from an overthinking/over prepared engineer impatiently waiting his Ct4-V B.W.The OEM center caps fit without any modification?
Not exactly, the factory wheels use a tapered lug seat so when all 5 lug nuts are torqued down (ideally in a star/cross pattern), the hub is still floating in the bore.Not true, the factory wheels are hub-centric
As some others have mentioned, no they do not fit the factory cap. Most of these fitments are BMW wheels with the right width/offset, which is going to be designed around the BMW cap. There are stickers on Etsy you can overlay if you don't like the Apex logo cap that comes with the wheel.The OEM center caps fit without any modification?
They have produced OEM spec bronze wheels but they are not always in stock. They often have sizes that are compatible with spacers and wheel rings etc. I'm using these and I think the fitment and offset look great. I should also note that they have several styles of wheels available in bronze.Are there any OEM spec bronze wheels available for the ct4 v blackwing? I'm not finding any on the apex site.
That looks great!They have produced OEM spec bronze wheels but they are not always in stock. They often have sizes that are compatible with spacers and wheel rings etc. I'm using these and I think the fitment and offset look great. I should also note that they have several styles of wheels available in bronze.
I am a big fan of the OEM bronze wheels...and wish the car came with them. That being said - there is no comparison with the Apex wheels which (arguably) look better/more aggressive and are much lighter. Apex all the way IMO.That looks great!
I am debating between these and the cadillac tech bronze wheels.
