We must be confusing our terms. Im using apex to define the pointy part in the middle that doesnt have tangency. As long as the splitter over the tires clear the ramp, at no point should the apex or anything else constrain you assuming you drive straight up the ramps. The leading edge sweep makes the portion of the splitter over the inside of the tire the pinch point, assuming constant height over the ground.That makes no sense. Of course the distance from the front tire to the apex of the splitter matters as well as the height of the splitter off the ground and the geometry of the ramp. I’m not saying his splitter is any different, just stating basic geometry considerations.
