4BW General Questions Thread
Anybody else had issues with the tire temp readout? For instance today I was on the highway for 30 mins 70-80mph in 100+ degree weather and it said “cool” which it obviously was not before suddenly jumping to “warm” (“normal” never appeared)
I am thinking this is related to getting new tires last week. Not sure if this is something that can be recalibrated or I’m going to need to get the sensor replaced
Those are in reference to tire temps. The info can be cycled off.
I have two questions wich I don't expect to find an answer easily,
- Is there a way to have the tire pressure in PSI and the cluster in KM/H ?
- Is there a way to see all the lap times of one session/recording of the PDR on the main infotainment screen ?
What is the small cylinder shaped piece with the rubber cap? Found the cap to be off so fixed it.
^Fuse fix didn't help. I mean, guys, am I going crazy? I took a few more videos today. It sounds like a fluorescent light under load I think - no? I'm hearing three layers of noise, one being normal engine exhaust noise, one being road noise, and one being a higher pitched buzzy sound. I just want someone to verify that it sounds odd before I start complaining to the dealer. Lol.
Bumping this because I found someone on FB having the same noise. Anybody else?
The guy on FB is getting his fuel pump and fuel lines replaced next week.
A shot in the dark here, but I read above somewhere that the noise went away when the clutch was depressed. If so, could it be a faulty clutch throwout bearing? I had issues with those on STIs.
