Fawkes
I could not get that quickjack pinch weld block to fit on the rear jacking point of the CT-4 BW. They also make a pinch weld puck, which I will try next.
I don’t think you have to have something sit flat recessed into rear cradle brace because it’s just under 3inch wide flanked by vertical metal sides. My 3inch wide hockey pucks lifted the brace at the outer vertcial sides of the brace just fine. The QJ 4in blocks would do fine as well. You don’t try to use the pinch well channel on the blocks for against the rear cradle brace did you?
