AbsurdBuffalo
Wanted to share some learnings from last night regarding the SD card formatting for the PDR and Surround Vision Recorder.
First, the PDR (SD card slot next to steering wheel)
Card format must be Fat32. If your card is formatted in exFAT (it will be if you buy a brand new one and don't stick it in a computer), the PDR system can format the card properly. However, if your SD card is formatted in NTFS, PDR cannot format in Fat32. You will need to re-format the card back into exFAT via windows then let the PDR do it's thing.
A note if your SD card is over 32gb:
Windows cannot easily format SD cards in Fat32 over 32gb. Linux can. So can your PDR as long as you format the card BACK into exFAT (this is the easiest option)
Second, Surround Vision Recorder:
This is the SD card slot in the trunk (if equipped). This must also be Fat32 formatted. If you have the PDR, simply format your SD card via the PDR as mentioned above, remove the card from PDR, and install in the trunk. The SVR system is apparently incapable of formatting cards. If you don't have PDR, but do have SVR (i'm not sure if this is possible, but if it is), and want to use a card bigger than 32gb, you will need to format in Fat32 using some form of Linux or alternate methods on Windows.
While on the subject of SVR, which is part of the parking package, this is basically a 360view dashcam. It will automatically start recording when accessory power, or the car is turned on if an SD card is present. Videos can be viewed directly from the 'video recorder' app on the main infotainment screen. From this screen you can save videos of interest so they don't get overwritten. Videos are saved in 5 min blocks. No audio. Video includes front, rear, left, and right cameras. It's actually quite nifty.
The PDR can also be set to record automatically when the car is turned on. Both the PDR and SVR can record at the same time.
The TL
R is,
SD cards must be Fat32 format. Windows sucks at doing this if over 32gb. The SVR is a 360deg dashcam.
Also, this is for a 5BW. 4BW folks, the PDR section would apply. The SVR section doesn't as it looks like it's not an option on the 4.
The TL
