Auto Rev Match
CT4-Villain
Ohio USA
2026 CT4-V Blackwing
My 26 CT4-V BW (with Rev Match turned on) wants to blip the throttle even when I'm not downshifting, usually after downshifting from 6th thru 3rd gear and then coasting the rest of the way. I find this odd if not a little annoying. Anyone else experiencing this ?
If you're anything like mine, you'll find it happens occasionally when you don't want it to. My most annoying moments are when I'm trying to parallel park usually in a congested area full of walkers. It will rev after I've nursed the clutch into a spot as I release clutch without a gear engaged. Annoying and seems pretty dangerous if God forbid I was in a gear and it just decides to rev on its own. I've video'ed it happening a couple times and shown my service writer. I've had a tech look into it although I don't think they looked at a thing as they said nothing is wrong. Sorry but you can't convince me everything is peachy. This was right after parking in the garage. Both feet far removed from the pedals:
P5CjH09.mp4
ETA: I am struggle bussing to get this dang video to load
My car will blip the throttle if I’m ‘downshifting’ into neutral as it’s anticipating me shifting into a lower gear. I don’t know the other variables which might be contributing (brake, speed, etc.) but I consider this normal behavior and it doesn’t bother me.
This seems to be a thing with GM's implementation of rev matching, as far as anticipating a downshift when you are merely going to neutral (I find it happens more "reliably" when I give the stick the neutral wiggle). My C7 did the same thing and it was always an annoyance.
There are two, possibly three different issues.
When coasting in any gear (clutch engaged but fully off the gas), engine braking is intermittent. Every few seconds the computer adds enough gas to make the car feel like I've just disengaged the clutch. This is most noticeable in lower gears where engine braking is more evident. It's annoying but easy enough to work around.
When shifting into neutral while rolling and planning to leave it there, my computer blips the throttle if I move the shift lever sideways at all (eg. shift to neutral from 5th, move the lever a bit to the left as if I was starting to shift into 3rd). However, if I just move it straight back to neutral and do not move it at all sideways I do not get a blip.
I've never experienced the issue 1Evil55 described. It sounds like a genuine malfunction rather than just poor programming of the computer.
My theory is that if there is any sort of shifter motion in neutral, even from the tiny momentum of actually shifting it into neutral, it will trigger a sensor and anticipate a downshift making a weird rev as you coast to a stop.
For a heavy transmission that needs to be manhandled this sensor is way too sensitive for daily driving (imo) so this random rev in neutral happens 80% of the time.
I do think it adds to the telepathic feeling of the rev match system during performance driving though so I guess tradeoffs needed to be made somewhere.
As for 1Evil's vid I have never seen that
P5CjH09.mp4
Yea I'm not sure if it waits till I'm going into neutral or not, I'll have to pay attention to that next time but that's what it seems like to me too, the computer is anticipating the next downshift. The car I had before this (23 Toyota Supra) had auto rev matching and never exhibited any odd behavior like this. I guess that's asking too much of GM engineering to test these systems out before they go into production.
Confused Will Ferrell GIF
Mine also does extra blips from time to time, usually when I'm decelerating in neutral and move the shifter side to side to confirm neutral. I like it. Remember, the difference between a feature and a big is just your mindset.
My mindset is a 70k car should do everything I tell it to do and nothing I don't.
I don’t think any $70K is perfect. Are you sure you aren’t moving it a little past neutral and not directly into neutral? I’ve noticed as another poster mentioned when you move it to the right or left or even slightly forward or backwards out of neutral like you are about to go into another it will blip the throttle. I think the rev match works really well IMO but I don’t have any other experience with rev match on other products. Worst case scenario you could turn it off and learn to do it yourself? I have been driving manual my entire life but only recently learned to rev match in my Miata once I experienced it in my Blackwing. It’s fun and it’s like learning a different level of driving manual.
Yeah mine does the random blips too when shifting to neutral - seems like the shifter sensors are just way too sensitive and it thinks you're about to downshift when you're really just going to neutral.
Most annoying thing is putting the car in neutral when parking and engine revs when at a stop. Only occurs when in first gear and putting it in neutral so the rev match feature is irrelevant given it has no function for upshifting. It does this regardless if rev match is engaged or not.
Yup. It always happens to me when parking and of course there are families around that then look at me like I’m some kind of asshole revving his motor.
