Sounds like an insurance claim waiting to happen. I would just rent or borrow someone else's car than put a roof rack or tow hitch. Or give up biking.:_rock
Yeah I wouldn't trust my expensive bikes on top of my even more expensive car using suction cups. But that's the only option I've been able to find. GM even has it as an accessory on some site. I'd much rather Thule make a kit to firmly attach but either there just aren't enough CTs made to make it worthwhile or it just isn't feasible. Roof mount points are the one feature I miss from my old BMW.
U-Haul make good hitches. I installed one on my wife’s Mazda. It is well made and was decently designed such that it was a fairly easy install. They will make one for any car if they can get some time with the car to be able to do the design.
Your vehicle requires a custom-built hitch​
If U-Haul doesn't have a hitch for your vehicle, nobody does!
Your vehicle requires a custom-built hitch which we will gladly fabricate for you. If you are able to bring your vehicle to our Tempe, AZ Research & Development facility we'll provide you with a free U-Haul custom trailer hitch, including free installation, and a lifetime unlimited warranty in exchange for the use of your vehicle to fabricate the trailer hitch. We'll need the vehicle for four to five days. If you are interested in this offer please complete the form below and we'll contact you to schedule your appointment. This offer is only valid until one customer per vehicle can fulfill our requirements.
Cleaned her up after an afternoon drive. Heading to an early cars and coffee tomorrow.
Are those lights in the bottom of the door or at the bottom of the car?
These replace the OEM puddle lights at the bottom of the door. The OEM lights simply cast light onto the ground when you open the door. These project the word Blackwing & the wings. You lose a little in the sense they don't illuminate as much of the ground with the OEM light but the trade-off is they look cool (IMHO).
Where did she fund those?
Was funded by P.O.S. Motorsports. 🤪
But if you're asking where she found them, it was in my original post as an embedded link in the text but here ya go:
I have them on my bw. They looks great although ones of them burned out within a couple of years of low usage on the passenger door. When my new bw gets built in going to get the ones from savage instead.
Returned that car back to factory/stock, to get it ready for sale.
From my experience-
Returning the exhaust back to factory is quite a chore! mostly, getting the electronic valves back onto the factory system is painful. For anyone else that ventures down that road, I hope you have patience.
The Corsa system uses a standoff system with screws that, during install, you can twist the valves and pop it into place.
Going back to factory, though, the standoffs are replaced by studs and nuts that make it impossible to do in the similar fashion as the Corsa install. I had to use the new fancy HF Needle Nose 8" pliers to turn the electronic valves fully, line up, and in a swift motion yank the pliers away while pressing the valve into place. Took a few (or more than a few) tries to get it aligned correctly. I had moments of surrender when trying to figure it out.
Also, if anyone cares, I did not have any CEL reappear when returning to the factory system.
I put a crack in my front floor console trim piece trying to remove it.
I'm installing the Rockford Fosgate remote control. I tried to run it up the center of the car. The plastics on this car are a pain. Running wires is always an issue.
