Tony Cadillacs
- Joined
- Oct 14, 2025
- Messages
- 17
- Location
- Long Island, NY
- V-Series Cadillac(s)?
- 2022 CT4-V / 2026 CT5-V Blackwing
That the heated steering wheel and heated seats come on automatically. Is there a way to turn this off?
To disable the automatic heating of the seats and steering wheel in your 2025 Cadillac CT5-V Blackwing (which activates by default when the outside temperature is cold, typically around 48–54°F based on user reports, and the HVAC is set low), follow these steps via the infotainment system:
1. Tap the Climate or Settings icon on the 33-inch touchscreen (home screen).
2. Navigate to the Comfort or Climate submenu (it may be under Vehicle > Comfort & Convenience).
3. Look for Auto Heated Seats & Steering Wheel (or similar phrasing like “Auto Heated Features”).
4. Toggle the option to Off.
This prevents auto-activation on startup. You can still manually turn on heating as needed via the physical seat/steering controls or touchscreen. If the exact menu label varies slightly, refer to your owner’s manual under “Climate Control” for confirmation. The feature is factory-enabled for convenience in cold weather but can be re-enabled anytime the same way.
