mfcentex
To change the transmission fluid, you would need to get whole car lifted. You would want to get it level.Where is this specified and how is anyone supposed to get it to that level? It sounds like others are overfilling it by filling it till it weeps out the top hole.
And how do you get an accurate fill level if you back up a 5BW onto ramps to do this procedure?
You can suck out 8 ounces after it is full. This is related to the transmission:
Transmission fluid level MUST be 3.2 mm (1/8 inch)below (1) the transmission oil filler plug. This can be done by one of the following two methods:
- Bend mechanics wire to 3.2 mm (1/8 inch) to check fluid level. Add or remove fluid as necessary.
- Fill transmission until level with the bottom of the transmission oil filler plug hole, then remove 240 ml (8 ounces) of fluid.
