Trunk Issue
DonD
Central TX
2023 CT4-V Blackwing
Would someone tell me how to remove the large, hard plastic part that the trunk latches into? Thanks, Don
I took mine off last year when I installed the sequential brake/signal lights. I am pretty sure that you must pop off the square black cover where the latch is. You will see a very small notch. Then IIRC you will see some bolts. Also, you must pop off the covers where the cargo latches are for more bolts. Mine were tight as hell and the socket had to be hit with a hammer to break the torque, then you can pop the black long cover off.
I am going by memory from about a year or more ago.
*** Mine is a CT5-V BW but they are probably the same.
They should download when you select them. But here are image snapshots of those pdf files:
