OK, I did some testing, found the fuse, and did a test drive. TL;DR: the piped in audio makes a TON of difference. In fact, all the weird, higher-pitched-than-it-should-be sound we hear at WOT is piped in through the speakers. WOT sounds a lot more natural (and, sadly, quieter in the cabin) with the F26 amp fuse pulled.
@Mirza Grebovic *please* see if you can get them to let us turn this crap off with an OTA update.
Detail, if you want to replicate this for yourselves:
1) open your hood and get the fuse puller from the underhood fusebox
2) open your trunk and access the trunk fusebox:
2) Use that fuse puller to pull 40A fuse F26, which is near the top (the diagram on the back of the cover is upside down):
* note, as you can see above I initially did both F26 and F42 as they were both labeled AMP.  You can ignore F42; I'm not sure what it does but pulling it doesn't block the piped-in engine noise.
3) Go for a drive and hear for the first time what your Blackwing really sounds like at WOT.
[edit] 4) put the fuse back in because there's no radio/audio at all with the fuse pulled.
Cheers
