CT5-V Blacked out badges, colored centers..
Got a confirmation on the Blackwing badge from Caddy/GM today for the 5. Sometime after October, but before the end of the year from what I was told? Asked them to send me one of those $$$ 120th Anniversary badges! May have a home for one of those, tribute ride! :)
Blacked out front and rear badges and left colored centers. Ordered Piano Black Hyperdip online and used that for its glossy finish. Front Cadillac emblem pops off easily with a finger in the grill and pushing the top tab down to release. Rear emblem has two tabs that have to be released and has emblem tape holding it down. Tabs can be accessed by taking off the inner trunk liner (google search ct5 trunk liner removal) . Use fishing line to cut the emblem tape off. Once badges are removed, dremel/drill the backside pins and inner piece will separate from the edge. Paint the chrome surround and reassemble when dry with some superglue. I also blacked out the V emblems. Tried to tape off the inner colored sections but the dip would peel off with the tape, so I just painted the Vs all black. Overall, pretty simple job and cheap at $20 for the dip.
Di
I’ve got one shot from the back and one from an angle. I can get a closeup if needed.
View attachment 12052View attachment 12051
Is your ride just incredibly clean right now or did you black out the grill and other black plastic on the front of the V? It looks really good and very gloss black where mine, even when clean, has more of a silver black look to it. I like yours a lot against the blue car. My V is black so not sure how that would look. Or maybe you didn’t even do anything. Thanks for letting me know.
Ok finally got some good pics of the blacked out badges on my 5BW. Moved the side V badges from the fender to the doors, and changed all the yellow in the GM black badges to gunmetal to match the rims. I also changed the Blackwing lettering to red to give it a pop. The GM black Blackwing badge had no color and was hard to read. Let me know what yall think.
That looks great!
I've got to say, your car looks fantastic! You really pulled it off with the contrasting black trim and the wheels complement the lines of the car so well. I'm assuming you vinyl wrapped the roof in gloss black.
Are you on stock springs and stock tire sizes?
Yes the wrap on the roof is gloss black. She is coming along pretty well.
The G3 CTS-V hood is coming next. I want to get the OEM style CF front splitter also. If anyone knows a great place to get this please let me know.
Also I installed the swift springs from Tapout, and the rim specs are below. Currently on factory tires, but plan to go 10mm wider front and rear.
Front 19x10 ET 20 (8mm spacer with extended studs.)
Rear 19x11.5 ET 48
Are you sourcing Savage Cadillac for the hood or another vendor? If its other, Savage also has a paintable G3 "type" Vented Hood and a full CF hood in production which are beautiful for the 5BW.
Both pieces look fantastic! I believe he has the 5BW CF splitter as well, or it's in production.
Give Oliver a call at Savage, he's a good guy.
Yes I actually have the Savage hood in my garage now. I just need to get it painted before I install it. It looks really good. Fitment is not perfect, but aftermarket parts never really are.
You have adaptive cruise control?
Where did you get the badges from?
Replaced the front and rear totally black Cadillac emblems on my 5BW with the ones that are black with colored centers.
The front was a piece of cake to install. The instructions that came with the emblems called for removing the entire front clip. I just stuck my finger in the grill openings and broke off four of the tabs and the emblem fell right out.
The rear was a bit more difficult. Removing the trunk liner wasn't quite the piece of cake as the front emblem. I ended up breaking one of the clips that holds the liner in place.
Once the liner was off, the instructions called for squeezing the two pegs on the back of the emblem while at the same time using a trim tool to pry the emblem out after applying some heat to it. No way you can do this by yourself. That's a two-person job. I ended up using pliers to snap off the two pegs and then I used the trim tool to pry it out after applying some heat. Came off pretty easily that way.
Yes, looks great. I pryed the front one out in 5 seconds, cracked just one of the clips,not like I cared anyway.
Can get the wheels too:
Not sure I've ever seen the 'tophat' PPF application done on a sedan before. Usually just trucks. I gotta say it looks good and definitely caught my attention.
From what I can gather, the previous owner had a battleship grey wrap applied to the body of the car. The factory paint is Raven Black. There is paint protection film over the wrap on the entire front-end of the car. Looks like the typical front-end, mirrors, and rockers ppf package. The prior owner also tinted the windows. The windshield has a shade strip at the top. It's taken awhile to get use to it. When I firtst got the car I kept ducking down to see stop lights. The window tint is too dark for me. I have a hard time seeing out the windows at night.
Those rear badge clips were a bitch to get out, glad I bought new emblems and weren't trying to paint the stocks ones. I went from "these will unclip no big deal" to "I'm going to break this clip into a million pieces so it's friend on the other side releases itself out of fear" in about 2 seconds. Blacked out rear looks so much better in my opinion. Shame on Cadillac for not making thess factory and selling them
I assume the V badge is the OEM blacked out badge option?
Is there really no black trunk emblem that uses the same colors as the OEM V badge?
Both sites have the CT5 version as well.
