Carbon fiber PN database.
Here are the OEM carbon fibers part numbers for both the 4 & 5 Blackwing. Use a variety of online sources to check prices such as Gmpartsdirect, GMpartscorp.com, etc.
CT4-BW:
Rear Spoiler PN 85561509
Front Splitter
PN 84433235(old)85563054(new)
Wheel deflector PN 84586281
Wheel deflector PN 84586282
Rocker Extension PN 84795019
Rocker Extension PN 84795020
Dive Plane PN 84996873
Dive Plane PN 84996874
Rear Valance Diffuser PN 84981410
CT5-BW:
Front Grille Header PN 86788444
front splitter PN 84432226
front side wheel deflector right PN 84490400
front side wheel deflector left PN 84490401
deflector kit PN 84624552
right rocker molding PN 84965190
left rocker molding PN 84965189
rear wing PN 85561511
rear diffuser PN 84981408
Seems like the part number for the rear wing has changed. Some sites say that part is discontinued.
According to parts.cadillac.com, the 5BW rear spoiler new part # is 85517784, if that is what you are seeking. Jameson’s Viggen updated his post if I remember correctly around Jan 2023. I believe others also have posted the number changed if you search even further.
parts.cadillac.com has everything you need. Good luck.
I'm a bit confused.
Are the OEM carbon parts the same as the non-carbon option equipped cars, just in carbon, or are they different geometry?
I'm a bit confused.
Different geometry. The non-carbon cars give you a plastic splitter, rockers, rear diffuser, and trunk lid. All are shaped differently in OEM carbon, and some of the pieces on the front end of both the 4 and 5 are only included in the carbon packs.
"some of the pieces on the front end of both the 4 and 5 are only included in the carbon packs."
This is a very important point. there are small air deflectors on the bottom of the carbon splitter for the 5 with CCB that I had to order in order to piecemeal it together. There is another thread at the part numbers -- we believe they are important if you have the CCB.
got it. I'm trying to find differences in the carbon skirts, diffuser and splitter but they look really similar.
CT4-BW:
Front Splitter
CT5-BW:
Are these numbers for a 2025 model?
I have been trying to get the rear spoiler and front splitter for a few months with no luck. After a phone call to Cadillac it appears the spoiler has been discontinued.
That's strange. I don't think the part changes at all for a 2025, so they must still be making them. I'll readily admit, I did not like paying for CF1 and CF2, but I sure love having them. My first car did not have any carbon, but I bought the rear spoiler for 3k on sale and put it on myself. The OEM parts are very good quality.
@BlackDiamondCT5VBW the OEM rear spoiler shows out of stock, not yet discontinued as previously mentioned. It had changed part #’s, so make sure you are using the latest one. But you have to check frequently for stock. Suggestion - find a dealer who will order it anyway (some do and some do not) so there is a demand showing on the system once it come available. It will be filled faster.
As for the OEM front splitter, part #84432226 shows currently in stock. Currently Cadillac is offering 20% discounts through their sites, but some other online sites show even deeper discounts than that.
The OEM pieces are very nice and v-matched, making them unique, like your Black Diamond color.
Good luck.
Started doing a little digging:
2025 + CT5-V BW
42795061
- Front Splitter
84490400 - Right Wheel Deflector
84490401 - Left Wheel Deflector
85561511 (or 85517784) - Rear Spoiler
87825668 - Rear Diffuser
If anyone could confirm that would be great!
There are 4 screws and 3 clips per side. The clips are NOT easy to get to and remove. Certainly not easy to re-install either. You can wrap it while on the car, and that is what I would advise.
Here are some pics of the pieces off the car, including a few of the clips... They slot in from the top and have to be pushed in and up to remove.View attachment 18332View attachment 18333View attachment 18334
SWEET LORD. Those clips were a pain in the... I don't have a lift and had to do it blind. I had to resort to rolling onto a brick to get a better look. The 2 outside ones were OK but the middle one was hard to reach and when it did pop out, it flew into the front fascia and I can't find it.
The problem I have now is that I can't figure how I'd even put them back, the spacing is so tight I can barely fit my fingers into position to seat it. I'm only replacing mine w/ the OEM plastic splitter. Do we really think those clips are necessary? I'm tempted to not even try to put them back and just rely on the 4 torx screws. Thoughts?
You can just do as I did with my CF splitter, install all the screws and JUST the outer clip on each side as they are manageable.
is there a OEM Parts site that sells parts for 10% over cost? i am aware of a few ford parts departments around the country that do this but not anything for Cadillac although i have not looked. Could be a way to get these carbon fiber parts under full retail price.
Most of the online stores (really just dealers using online marketing) typically have significantly lower prices than retail. Not sure what the at cost values are, but you have to respect the shipping costs for these parts because they can be substantial.
The local dealer I bought my 5BW from sold me a splitter below cost. I don’t think you can get that kind of deal, but they may do 20% off or so. The thing about the CF parts is if there is a defect it can be dealt with right at the local dealer. I took the splitter out of the box and inspected it in front of the parts guy.
As mentioned some online places add $350 for shipping a splitter. If you have to return the part you’re gonna eat that plus the return shipping.
Any GM parts supplier can provide Cadillac parts. Beware of shipping costs!
It may have been mentioned earlier in the thread, but Auto Addicts makes an almost perfect replica kit. I had them install it and the fit/finish is indistinguishable from OEM. I know it is not right from GM, but it will get your there! Rear wing attached for reference.
They also make Carbon replacement pieces for some of the front vents.
Good company, good team. I had them do wheels, tires, springs, alignment, and a few other things. Nothing but good things to say!
(Not affiliated with them in any way).
-eric
