LongGrayLine16
- Joined
- Jan 11, 2022
- Messages
- 167
- Location
- Manhattan, KS
- V-Series Cadillac(s)?
- 2023 CT5-V BW (86-027)
1. Hold ignition button for 5 seconds without touching brake or clutch. Car will go into ‘ignition on’ allowing you to change everything as though the car was running.
2. My ‘My Mode’ is set to stealth. I leave daily at 0510 and start the car in the garage while the wife is still asleep.
3. Let’s be honest, everyone should be using ‘V Mode’ for the burbles. Set it to track exhaust. When you start you will be in tour mode by default if you turned off in v mode.
4. Immediately after pressing the start button press the v mode button. Valves will open before the car starts giving you a track mode startup
