Subwoofer install ANC Help
Triplejs has a powered sub so no line level converter required but does also have RCA inputs so can use a converter, i am going a similar direction so was curious how his is wired.
What fuse did you tap into for the remote on wire? I was planning to use the sunroof fuse(I do not have a sunroof) in the rear box but I think it is always on.
I used the LC2i. It has a signal sense and turns on based on the signal from the speakers. I might look at fuses in the future, this seems to work for now.
What plug for harness on amp on 26 BW5? seems to fit rear most but looks like will fit the front most of the 3 plugs so confused
