For Sale Selling My CT-4 V BW Speced Aerolarri Wheels and PS4S Tires
Infinityli
Michigan
2023 CT4-V Blackwing
TLDR: Selling custom forged Aerolarri rim (stock 4BW spec) + stock PS4S Tire package, have less than 3000 miles usage, local pick up only near Warren, Michigan 48092
Price $2500 for tire + rim
Hi All, my CT-4 Blackwing got rear ended + totaled last December, during the crash I have the stock rim and a set of Nokian Hakkapeliitta R3 winter tires on and the custom Aerolarri wheels with PS4S tires was in in storage at discount tires. Sadly though I have decided not to go for another BW so I'm trying to sell the tire + wheel package. Both the tire and the rim have less than 3000 miles on them, and are already balanced with stock GM TPM installed.
I'm sure plenty of you know the 4BW wheel spec very well, but just in case here are the detailed spec of the tire and rim:
Front: 255/35R18, Rim Width 9 in, Offset 28mm
Rear: 275/35R18, Rim Width 9.5 in, Offset 48mm
Here are some photos of the wheel by themselves:
Here is how the wheel look on the car:
Please reply to this post or PM me on the form if you are interested in purchasing this package, I hope you can put it to good use on your BW.
I would be interested but a bit concerned about the offset in the rear. Do you have a picture along the body from rear to front to see how much they stick out with the 20mm lower offset? Although you have the rear listed as +28mm it is actually +48 mm. So if these are +20 they are near 0.8" different.
Here are the OEM wheel sizes:
Front
18x9 28mm Offset 5x120 72.56 Bore
Rear
18x9.5 48mm Offset 5x120 72.56 Bore
What are the Aerolarris?
I did email Aerolarri and all they said is they make custom offsets. So they must have built them to the specs you requested. Let me look at the pictures a bit. You have 3000 miles on the tires? Where would you be shipping from? Mounted wheels and tires can be shipped but it is a bit expensive to do.
I would be shipping out of Warren, Michigan, if you are near this area you are welcome to come and pick it up.
Great looking wheels but I am going to pass. I always kept 3-4 sets of wheels and tires for my Z06, but now life is simpler and finally realized I didn't want to get back into keeping extra stacks of gear around. GLWS. They are worth a repost on the forum as they should go readily.
