Rev limiter = kill switch
CBH
Austin, TX
'23 CT5 Blackwing w/ Clutch
I hung onto 2nd gear a little too long recently, and was punished sharply for it. Obviously you're in a hurry if you're redlining the car, so it was a nasty surprise when it simply shut down in response to my late shift.
It brought back memories of the bad ol' days in my E34 530i. That car lived for redline, and it was so quiet that it was easy to reach unexpectedly.
I thought I had hit redline in the BW before, and that it much more gently held you at redline rather than whacking the ignition to cool things off.
So I'm crazy ? It never holds redline, but always just whacks it until you back off ?
I don't know if it cuts fuel or spark or both, but i nearly hit my head on the steering wheel when it happened.
Like i said, I thought I had hit it before in a much less violent way.
That does not sound normal, but maybe you were on the red longer than you thought and it is a safety system? I have seen countless videos of guys bouncing off the redline, and they never get shut down. I have hit mine multiple times on both my 22 and 24 and also never had that happen.
Just curious, were you wearing your seatbelt? That should catch before your head is almost banging off the wheel.
2nd gear still has some leverage vs a higher gear, so seems plausible that a combination of that, you not expecting it, and a dash of dramatic reaction influenced your perception? Try it again and report back :cool:
Now that's good advice :)
Might be a while, but will do.
I think the opportunities to redline much higher gears is pretty limited on public highways. I guess 3rd is OK at 120. Same Google search said 200+ in 5th/6th, but my math shows 5th won't go that high before redline, and the huge gap into 6th would likely kill momentum. I'd like to be able to test that, but probably won't. Even our tollways are too rough to take chances at that speed.
Exactly right. Fifth will get you to about 165, then the shift to sixth drops RPMs ALOT reducing accel. rate.
This video shows it well:
I don't think you hit 120 in 3rd. At Spring Mountain, I was using 4th on the 1 long straight on the North track, I think 116 was my top speed. Maybe shifting out of 3rd at 110 +/-.
Had her out last week and hit the limiter at the end of 2nd again.
It was still very abrupt, but I guess knowing it was coming makes a lot of difference.
Nothing like the rice rockets where the kids pin the bike in WOT in the parking lots to listen to it bounce off the limiter till they let off.
Not like I want to try that.............
