GMPP Question
schernov
Chicago
22 CT4V BW
So I have a GMPP platinum contract with zero deductible. Took car to my dealer for two error messages "service cluster", " service power steering" and for massage button on driver seat being intermittent.
Messages popped up twice and went away on their own.
No DTCs stored but there was a firmware update for cluster and for BCM which dealer did.
GMPP refused to pay for it. Called them directly. They argued two points :
1. There was no mechanical part break Down. And
2. Software updates are "maintenance".
Has anybody experienced same ?
If they're not going to cover basic diagnostics, then it's not a very good value proposition. It isn't like you brought it in and complained about a phantom noise. There were actual trouble codes on the screen. The irony is if you DIDN'T bring it in after those codes and something failed they'd probably use that as a reason not to cover...
See if this exclusion or something like it appears in the contract: “software updates related to multimedia system (unless a ‘malfunction indicator’ light is on or your vehicle does not operate properly)”
The service cluster message is sort of known deal. I've seen it twice for a split second. Service power steering, haven't seen that. It could be just another phantom error message these cars seem to be prone to.
Steering rack had latest firmware. And no DTCs. Happened right after swapped summer set f wheels for snows ( oem wheels) so maybe with car being jacked up one corner at a time some sensor freaked out.
I am going to call GMPP Monday and dispute.
Called GMPP.
basically- no failed part - no coverage for stand alone programming.
why not?
stand alone programming, per GMPP is considered "adjustments" which is excluded.
Called GMPP.
why not?
How did the software suddenly start causing these errors. That’s strange unless it became corrupted somehow. I guess their claim that it is maintenance means the software just got old and wore out.
