Slick Blackwings
- Joined
- Jul 25, 2021
- Messages
- 501
- Location
- N.E Pennsylvania
- V-Series Cadillac(s)?
- 2022 CT5 V Blackwing. 2024 CT5V Blackwing
Is it me or did I miss something, but this is happening to just manual transmission cars?
Interesting that engine issues are being seen so early and so often. Same basic motor went in the current ZL1 as well as the last Z06.
From what I’ve learned on my kerfuffle is that it’s not the same motor and the hand building process sets it apart. The RO for my motor replacement came out to around 50k and the long block was about 25 of that
C8 Z06’s came with hand built motors as well as a few ZL1’s.
C7 Z06 I think you meant to put. The ZL1 was a different supercharger slapped onto an LT4. The Z06 I don’t believe ever had hand built motors with the titanium valvetrain like the blackwings
The zo6 lt4 has a name plate of the builder on it. Atleast my buddies 2019 does.
Te
The Z06 LT4 was hand built and have plaques (mine does). The LT4 in the ZL1 also started receiving plaques after 2019 I believe. The ZL1 LT4 is the same as the Z06 LT4 minus the dry sump. They have the same supercharger. The Escalade V is running the LT5 2.65L blower on its LT4 but the Blackwing (again without dry sump) uses the same engine as the ZL1 and Z06 with some slight revisions to exhaust, induction and a taller lid which gives it the 18hp over a Z06 or ZL1.
Before reading all of this I'm like:My ZL1 LT4 was hand built by Mr. Zach Lamb on the build plate. They were hand built when they could keep up with demand. It is cheaper to build them by hand for low production vehicles vs. retooling.
Z06 article.
All Corvette Z06 LT4 Engines are Now Hand Built in Bowling Green - Corvette: Sales, News & Lifestyle
Starting May 1st, every 650-hp LT4 engine that goes inside the Corvette Z06 will be hand-assembled by the Performance Build Center.www.corvetteblogger.com
Correct, I meant to say C7 Z06.C7 Z06 I think you meant to put. The ZL1 was a different supercharger slapped onto an LT4. The Z06 I don’t believe ever had hand built motors with the titanium valvetrain like the blackwings
I say a prayer daily that nothing happens to my wings! And I pray for this forum!Before reading all of this I'm like:
As I read this I hear in my head:
After reading this I'm like:
Seriously though, I love reading and learning from everyone's experiences/research.
Great forum...
So I am finding out. it shouldn't be this complicated. Everything is going through GM and they were pretty well shut down last week for the holidays.You only need four things to make it fire, Air/Fuel mixture, Compression, Spark and at the right time. It should not be hard to find out which of these is missing.
The issue is with how the manufactures handle warranty work. They wont let the dealership techs diag the problems anymore. They work under the strict guidance of the manufacture which adds a huge delay between each test, report, diagnosis and finally repair and verification.
Really. Hmmm.You only need four things to make it fire, Air/Fuel mixture, Compression, Spark and at the right time. It should not be hard to find out which of these is missing.
As stupid as it sounds I was suffering from a misfire in my new motor after the new one was dropped in. Turns out the spark plug wires (because some genius decided that there still needs to be those on a car with coil packs) were loose and would slip off the connections. With the engine vibrations and bumps on the road, the wire on cylinder 7 popped off. It was an easy fix for me, hopefully it's something easy for you. I'm surprised they didn't just get a new motor shipped and dropped in. Maybe mine was extreme with the rod bearing delete package but if it's been a month I'd ask for a new motor and GM can figure out where they went wrong on this one.Update - no Update
After almost a month, no progress on my car. Service keeps saying that they are talking with GM and sending them files. They say they see a misfire in cylinder 6 but nothing they have tried so far has fixed it.
Everyone I have dealt with has been great but the lack of ability on GM's part to resolve the issue is getting beyond frustrating.
It is so bad I have set the radio stations in the loaner to my favorites, including Sirius. Maybe I shouldn't have purchased winter wheels/tires, I may not need them.
Seriously, I can't count the number of cars I have owned and have never experienced anything like this. I know these cars are complicated but with all the electronics; you would think they could diagnose something like this.
I guess I am done venting.
Man I hope they sort it out, best of luck moving forward!So I am finding out. it shouldn't be this complicated. Everything is going through GM and they were pretty well shut down last week for the holidays.
Thanks!Man I hope they sort it out, best of luck moving forward!
They have targeted the 6th cylinder ...
I paid out of pocket for the dealership to take a look at that cylinder during my first oil change. Thankfully they said it looked clean.That's the same cylinder in which Mcard23's car ate a plug.
And the same cylinder that was most rekt when Car and Driver's car blew up.
100% AGREECylinder 3 and 4 were the rod bearings that were devoured on my car. I would again just recommend for them to get you a new motor and let them figure out what went wrong with it. It's not your responsibility for their fuck up, especially if you've been out of your car for longer than a month.
Oh no I actually had my rod bearings weld to the crankshaft. I’m the 2nd person to have a Blackwing blow on themI assume they saw material in the oil to diagnose the rod bearings. Just seems like a lot of people have had major engine issues and that is discouraging.
Did my first flat foot shifting today. It feels so wrong but also so good.100% AGREE
How's your car running now, hopefully good?
