Differential Plug Tool Size?
00 Scrub
CA, USA
I'm getting ready to do my 1,500 miles differential service and wanted to make sure I had the right size hex bit for the fill and drain plugs. Anyone know what size tool is needed? It looked to be a pretty big hex bit (12 or 14mm or so).
Access seemed OK, is everyone getting away with a 1/2" drive socket there?
Thanks
If you have a 5, it is a 14 hex at 37 ft lbs. Don't know if a 4 is different. Short extension is helpful for the fill plug.
For the 5BW, it is a T-70 torx. I just did the 1500 mile service on mine a few weeks ago. A hex may work as well, but I had the torx.
rvrrun, Thanks for the T-70 report- I'm close to to doing the fluid exchange myself (parking with 4" RaceRamp wedges so, hopefully I can squeeze/waddle under there "comfortably")
rvrrun, did you use an oil funnel or something to fill the fill-hole? (I have a syringe type tool thing oil injector plan). I also have a toothbrush to scrape out the bottom of the pumpin to see the OEM factory fill remnants of what comes out at 800, or so, miles LOL. Refit plugs will be magnetic top and bottom to replace OEM for more LOL's later.
I am doing this very soon
I'm doing this right now and just to verify for everyone, it's certainly not a T70 torx. It is a 14mm hex. The torx might fit, but it's really not the correct tool.
This is on a '26 5V BW
Why are you all changing dif fluid on nearly brand new cars? When I replaced fluid in my atsv at 20k, the fluid that came out looked the same as the fluid I was putting in...
The recommended break in for this car's differential is 1,500 miles before you should go over 80 mph or launch the car hard or anything. I just hit close to that mileage so I decided to change it. The fluid that came out was very gray in color compared to the light, golden color of the new fluid that went in. I'm very happy that I changed it.
I bought two Slippery Pete fluid pumps from Amazon. One for the diff and one for the trans. The GM fluid bottles are different sizes so I needed two, but would have done that anyway to prevent cross contamination. We have a bunch of four post lifts at work and it made the job a snap. I used our oil catch can to get the overfill mess and hoses it down with brake clean after. After reading the forums, it was recommended on the TR-6060 to fill to 3/32” (or some similar minuscule amount) below the fill plug level. I read that this was to prevent fluid from coming out of the vent after hard driving. I removed a bit by sticking my finger in the fill hole a few times and letting some dribble out, and have had no spots on the garage floor (yet).
