TRTL PWR
Does anyone have a preference for wheels and tires for track days. I am looking to do two days at COTA in march and questioning if the stock tires will hold up...
do you know of any r compound tires that would fit the stock wheels. I'm coming from goodyear supercar r's so I am guessing I will feel let down by the ps4s on trackI think it depends on your definition of "hold up" The stock tires will perform very well given their bespoke design with about 61% of the Cup 2's polymer. Still won't be as good a pure R-compound tire but probably last longer.
I thought the BW tires had some R compound in them?
I may try the goodyears with the 265 up front and 275 in back. the michelins do measure wider in the contact patch so i think the 265 up front will fit with the 275 in the rear leaving a bit to be desired....In the OEM BW4 size, the pickings are pretty grim.
I'm not sure anyone has started to verify what size aftermarket wheel can fit in the BW4 and 5.
You can run a R888R or the A7/R7...that's it for anything with a UTQG less than OEM.
IF you can get a 265 on the front wheel, you can run the Goodyear SC3R which, IMHO is the best track day tire available.
I'm almost certain the Apex wheels I have for my SS 1LE will fit the BW5 with a small spacer in the front. I plan on using the Goodyear SC3 and the Falken 660 as my track and AutoX tire.
