Cadillac chatbot decoder ring?
leres
USA
2025 CT5-V Blackwing
Ideally the chatbot would reveal the order code status number. It does not do that. I'm curious what the mapping is. I believe for codes from 2000 to 3400 it says, "Your vehicle has been accepted by General Motors and is moving forward to the production process." What does it say for codes less than 2000 and greater than 3400?
If you want the numeric status code you have to ask for a human advisor so they can pull up your order. A LOT of the status codes map to the same chatbot response so you have to ask a human. It's the same thing your dealer salesperson can do.
Mostly I'd like to find out when the car is built without bothering a human.
I think you have a better chance at getting your glass of ovaltine before Caddy delivers when they say they will.
That's one status the chat bot will tell you about. After that through all the shipping steps it'll tell you to contact the dealer for status.
Just type in Advisor and a live person will assist. Give them your order number and ask for the exact event code.
Perfect; thanks!
Starting yesterday morning (PDT) the bot was no longer able to find my order; this continued today. But I also received email from cadillac.com saying my car had been built and later my salesman was able to provide the VIN.
I got a live agent on the chat just now and learned that indeed, it was built yesterday.
As far as I can see the bot stops providing info on an order once it has been built.
Yeah at best it says "congrats your car is built. Your dealer is the best source of information on the shipping process."
That's pretty much what I was expecting but apparently not how it actually works.
I think the bot lost its connection to the order database because it's not finding mine either and mine is a ways off from being built. Either that or my dealer canceled my order (which I think would still show up as a canceled order?).
Looks like the chatbot regained it's ability to report order status today.
I asked for the advisor & all they did was regurgitate what the bot said & then told me to contact my dealer.
Depending on what the Bot tells you, you might not be able to get more info from the advisor. Bot won't give you the status code and an advisor can, but often you know the status code from what the bot's answer is anyway. When you get to a built status or if there is an issue with your build you sometimes an agent can give you things like expected ranges for when a solution or shipment might start (like 2-4weeks)
At the risk of getting flamed, how exactly do I access the Cadillac chatbot to get an order update? I've been on the website for more time than I care to admit trying to locate and I can't find it.
its usually down in the lower right. When I'm logged into my account I find it harder to get to popup than when I go to the site w/o being logged in.
For me if I hover in the lower right corner where it lives, it will pop up.
Bots...why are y'all are skerd to talk to a human?
