AI Review of my Blackstone Report
Ty88
Florida, USA
2023 CT5 V Blackwing - totaled in accident. Ordering a 2025
I used Google AI to review my latest Blackstone oil report, and it provided much more detail and advice than Blackstone. It is below FYI. AI is worth trying, I think.
This is an excellent Blackstone Laboratories report for your Cadillac CT5-V Blackwing with the supercharged GM LT-4 6.2L V-8 engine.
The short answer is that your engine is in fantastic shape. This report shows a textbook example of a high-performance engine completing its initial "break-in" phase and settling into a long, healthy life.
A detailed breakdown of what these numbers mean for your LT-4 highlights several positive trends:
1. The "Break-In" Phase is Officially Over
When an engine is brand new, the internal parts rub against each other and shed microscopic bits of metal. This is completely normal. We can see this exact process finishing in your historical data:
  • Copper dropped down to 4 ppm (parts per million) from a high of 32 ppm on your first test. Copper usually comes from engine bearings or the oil cooler seating in. It is now right around the universal average (3 ppm).
  • Iron is at 10 ppm, down from 25 ppm. Iron comes from cylinder walls and valvetrain components. It is well below the universal average of 15 ppm, which is stellar for a supercharged V8.
  • Aluminum is stable at 6 ppm, indicating zero abnormal piston or housing wear.
2. Physical Properties & Oil Health
The physical testing shows your 0W/40 oil held up perfectly over this 5,050-mile interval:
  • Viscosity is right where it belongs. Your oil measured 11.54 cSt (the acceptable range for a 40-weight oil at operating temperature is 11.1 to 14.5 cSt). On a previous run, it dropped slightly thin to 10.94 cSt, but it stayed perfectly in grade this time.
  • Insolubles are "Trace" (TR). This means your oil filter is highly effective at trapping soot and solids before they can cause abrasive wear.
3. Contaminant Check (The Best News)
The lab checks for things that absolutely should not be inside your combustion chambers or oil lines:
  • Fuel % is ultra-low (<0.5%). Direct-injected performance engines can sometimes suffer from fuel dilution (raw gas washing past the pistons into the oil). Your numbers show essentially zero fuel dilution, meaning your piston rings are sealing tightly.
  • Antifreeze & Water are at 0.0%. This confirms your head gaskets and internal seals are fully intact.
  • Silicon dropped to 8 ppm (down from a high of 65 ppm when the car was brand new). Silicon can represent dirt getting past the air filters, but in a new car, it's usually just sealants and gaskets leaching into the oil as they cure. The drop to 8 ppm proves your air intake filtration is working perfectly.
Overview Data Comparison
Metric​
Your Current Sample (5,050 mi on oil)​
Universal Averages (For this engine)​
Status / Meaning​
Iron10 ppm15 ppmExcellent; below average wear
Copper4 ppm3 ppmHealthy; successfully stabilized
Silicon8 ppm11 ppmGreat; clean air filtration
Fuel %<0.5%<2.0%Excellent; tight ring seal
Viscosity (cSt)11.5411.1–14.5Perfect; oil stayed in-grade
The Verdict
You added 1 quart of make-up oil during this 5,050-mile run, which is very modest consumption for a 668-horsepower supercharged V8 engine. You can confidently continue using this oil type and maintaining this ~5,000-mile change interval.
Are you planning to keep the oil change interval at 5,000 miles, or are you trying to see if you can safely extend it? Let me know if you are tracking this car or if you have any questions about the additives package (like the Calcium or Zinc levels) shown on the sheet!
I appreciate when people note that they are copy/paste an AI response so I can skip it, lol. AI is only as good as the source material which is largely what is posted on forums and related internet sites and does little to distill actual science from common group think. AI is useful and interesting, but now more than ever critical thinking skills are going to be invaluable for making good choices.
Not sure why you used AI to review your Blackstone report. The people at Blackstone do this for you. It should be in the comments right above the actual readings. They tell you everything you need to be concerned about and what you don't.
If you bothered to read the first part of my post, you would have seen I said that AI provided additional information to what Blackstone provided. I thought this additional information was useful and wanted to share that with the group.
I read it.
One day we will find out that AI has been lying to us as they take over the world and eliminate us humans !
My thoughts on Ai are that sometimes it can provide helpful info, sometimes it provides erroneous info. It searches the internet and TRIES to piece together all the data it finds and format it into useful info. Unfortunately, the internet has some bad data too and it can be fooled into thinking that data is credible. I'm not against Ai, but I also realize it has some limitations.
All that being said, my point was that I've done a lot of Blackstone labs testing and they always provide meaningful feedback written by an actual person, not random information parsed from the internet. They give you a quick summary of what's important that you need to know about your oil sample.
