2025 5-BW Precision Package Questions...
Apparently the BW CCB require weighing. What a pain. If they form a lip when they get worn like iron rotors do then that will be a good visual indicator. I can usually tell when my iron rotors need replacing before measure the thickness.
Weighing rotors is common for CCB's - not unique to BW's.
The other advantage to CCB on the track as I understand; is that they do not overheat with Track use, and are not subject to brake fade. Also most BW's are multi use, daily drivers etc; therefore CCB will last alot longer, with limited Brake dust.
My car is serviced by a Dealer; at a point in time probably 30000 miles from now I will have them "weigh" my rotors I assume.
Having just done a track day at NCM in my ‘23 with iron brakes, I feel like the main thing holding me back is outright cornering grip. So many corners, I was having to hold back to avoid shredding the front PS4Ss. I didn’t feel like the chassis was a problem—with the track alignment, the car was playful yet predictable, as opposed to with the stock alignment where it seems to tend towards understeer and not have much interest in rotating on demand.
To be fair, my skill level and knowledge of the track (this was my first time there) were also holding me back, but I’m confident that grippier tires would have shaved a tiny but not insignificant bit from my lap times.
Also, I owe something like $60k on my 2023. I can’t justify multiplying that by 2.5, adding 2 years to my loan, and at least several hundred dollars to my monthly payment, in order to drop a couple seconds from the lap times.
I do regret the iron brakes, but only from a dust standpoint—they held up to NCM just fine. I found a vendor that makes custom CCBs and is getting me a set with pads for $7500 shipped.
Here’s my last and best session at NCM. Following a Porsche 997 early on. Skip ahead to 26 minutes to see me tailing a 911 Turbo S and a Cayman GTS for multiple laps.
Great Driving; when you say "Track Alignment" what were your changes ? After your Track Day, which seemed like a fair amount of miles; how did your tires look ? I have been impressed so far as to the lack of wear with aggressive cornering/ driving. If I had to guess a percentage of Track time, or Track like driving (Tail of the Dragon) it would probably be less than 20% of my total miles.
Here is what my tires looked like after one track day. They are Goodyear Supercar 3R. Camber is 2.8f and 2.0r.
OUCH.. Wow was it a hot day ? It looks like you have someone elses melted rubber on there as well. I will say that the camber adjustment must be pretty good they are worn pretty even, but really gooey looking. How many miles did you run ? So far I have been running in cool weather on the MICH PILOT SPORT 4S which came on my 25 BW with Precision Package, and not for any duration like you were. I guess the same CCB, but I think you will appreciate their braking feel/ power, durability and lack of brake dust !
It was actually a cool day under 70F. We don’t typically get hot weather up here in the PNW. The tires still got really gooey and picked up anything not glued to the road. A few hot laps scrub them clean.
The wear seems good with the track camber. A guesstimate is about 150 track miles plus about 70 highway miles.
I just took off the track wheels today. There was a lot of carbon brake dust along with a lot of tire rubber. Took some time to get them cleaned up.
If you are wondering how the 5BW PP did, my best lap was about 1.7s better than my best lap in my GT350 which ran Cup 2 tires. Some of that time is due to the sticker 3R tires. But there is still much more to wring out of the BW.
what track wheels did you end up deciding to use on the car?
what size 3R's? 285 Front and 305 rear?
Correct. Same size as the MPSC2 tire option on the PP. The rears are GM spec 3R (which were the front tire size on the Camaro).
I've seen several ct5 black wings approach the 150k mark and spending 100K was hard enough for this vehicle so I tried my best to eliminate as many options as possible aside from the seats.
However all the videos I’ve seen of reviewers raving about the PP had the Cup 2R tires installed. I’d wager those tires alone would transform the handling.
Then you figure the rest of the components were dialed in around the 2Rs.
Then you realize how massively impractical R compound tires are for a daily driven car in variable weather conditions.
And then you question paying all that money when you will not be using the main ingredient (the 2Rs).
Then you decide not to check that option box.
True story.
Try stepping up and talking in the first person - own your bias, fear, and lack of $$$.
You can do it - I have faith in you!! (y)(y)
I'm the opposite... why spend $100K, then stop short of the goal line? 🤨
Makes no sense.
Makes no sense.
this is how i feel as well unfortunately. car is still 120K without the PP, why not go all the way?
also, the car is not tuned exactly for CUP2R. Car has enough variance in its programming to work well with PS4S and Cup2R according to the engineers. thats definitely worth noting
Deductive reasoning is like using a scalpel instead of a butter knife.
I don’t need to recklessly spend money in a desperate attempt to force reality when using my brain already tells me everything I need to know.
I didn’t check the box for the reasons above. It made zero sense, regardless of the $$$ ability to do so.
If it’s all about bragging rights, spending the most dollars, don’t forget to check the box for the automatic transmission.
I have this battle in my head frequently. But I just want the best driving experience. I may get on the track once a year, but if the car feels better as I’m cruising around on my daily drives is the PP worth it to me? Hard to say that it’s not worth it. I wouldn’t want to regret not getting it but that’s a problem I have I guess. I would probably option for CCBs anyway. Had a CF gt500 and the wheel dust was crazy. Would be nice to not have the wheels dusted to death 30 minutes after washing it then going on a drive. Also, the PP will ride much more luxurious then the mustang anyway
