bl4ck_wng
Seasoned Veteran
- Joined
- Nov 11, 2022
- Messages
- 218
- Location
- Jersey
- V-Series Cadillac(s)?
- 2022 Cadillac CT4-V Blackwing
As promised, here is a summary on how to lift your 4BW safely using pinch weld adapters and a floor jack.
While this is the best method I have found so far, this is a living thread where any improvements or suggestions are always welcome. The only thing that I ask is that this particular thread remains on the specific topic of the 4BW, as the lifting procedure between the 4BW and 5BW is NOT identical.
As with lifting any vehicle, always chock your wheels from the opposite end to prevent movement, and use a level surface. Jack stands are strongly recommended for anything more than a quick wheel swap.
If you are ever unsure or don't feel 100% confident, just take a pic and throw it in here/ask away. This procedure is nice and easy, despite all the confusion you may have seen across the forums.
Enjoy and best of luck.
-AR
-AR
