raptor5244
- Joined
- Aug 7, 2022
- Messages
- 874
- Location
- Florida
- V-Series Cadillac(s)?
- 2022 CT4-V Blackwing - 46-381
My understanding is that the 5BW is good to go, you can use the same Camaro lift pads seen below. Great solution, they stay on the car all the time, used them on my Camaros. The issue is really with the 4BW that uses the Alpha 2 chassis. There are no permanent lift pads available on the market that will fit. I use this ZL1 pinch weld adapter with jack pad. It works ok in the rear pinch weld but it is very tight on the front and I wish there was a better solution for the 4BW, like there is on the Camaro/5BW. Furthermore, until I saw the post above from the service manual I had no idea where you should actually lift the car. You would think something like that would be posted in the standard user manual.
