Vigster
Not for us single guysI’m not sure about the 5 but, the one for the 4 is laughable in the context of actual groceries.
@GTANotch88 I picked up the factory rear CF 5BW spoiler have to disagree about the exiting holes. The outer required 35/64” bolt holes are not there on my car or I can’t see them (I haven’t taken the painted spoiler off yet). There are 6 factory pre drilled holes on the trunk lid; however, 2 of them are not used and appears you must drill 1 hole 35/64” on each outer side to install a plastic push nut for the spoiler bolt.No extra holes needed. They are all there already on the 5BWs.
@GTANotch88 no problem. I have the same holes that you show in you picture, so since the new hole will be under the spoiler then not scared to drill them. I can coat them to prevent corrosion as well. Hopefully somebody that has installed a factory one will chime in with any comments. It’s pretty straightforward, just curious.I stand corrected then. I swore several people had already installed it with no new holes needed. When I did my aftermarket spoiler I was surprised to see so many holes not being used at all. The little stock spoiler just had 2 locating pins and double sided tape. I assumed all bws got the same trunklid.
I read on the forum that the spoiler comes with a template for drilling the holes. Did yours not have the template? Having drilled a fair amount of vehicle sheet metal I find what works best is, 1) use a punch to make a light dent, 2) drill a pilot hole, and 3) most importantly use a step drill bit.@GTANotch88 I picked up the factory rear CF 5BW spoiler have to disagree about the exiting holes. The outer required 35/64” bolt holes are not there on my car or I can’t see them (I haven’t taken the painted spoiler off yet). There are 6 factory pre drilled holes on the trunk lid; however, 2 of them are not used and appears you must drill 1 hole 35/64” on each outer side to install a plastic push nut for the spoiler bolt.
The bolt I circled in red is one of the outboard bolts on one side.
Yes it should come with a template.I read on the forum that the spoiler comes with a template for drilling the holes. Did yours not have the template? Having drilled a fair amount of vehicle sheet metal I find what works best is, 1) use a punch to make a light dent, 2) drill a pilot hole, and 3) most importantly use a step drill bit.
I got a template for drilling holes and always perform the same steps as you outlined. I usually use blue tape where I perform the drilling. I’ve got all of the tools including step drill bits.I read on the forum that the spoiler comes with a template for drilling the holes. Did yours not have the template? Having drilled a fair amount of vehicle sheet metal I find what works best is, 1) use a punch to make a light dent, 2) drill a pilot hole, and 3) most importantly use a step drill bit.
For what it costs, it should come with an installer.Yes it should come with a template.
Ha! Indeed. I know it's quality, but the 4BW's retail price is silly imho. I can add a mezanine to my place for thatFor what it costs, it should come with an installer.![]()
I want some of them mirror covers, looks good!New cuff links
And some lights. Little by little.
Just carefully pop those mirrors out if you go for it. I mean carefully, they just click into a plastic bit that's not very sturdy.I want some of them mirror covers, looks good!
Got them both, like KatyTxCT5V states mirror light are a bit large but you get used to them quickly. The image they project is very sharp and clear. The door lights seem to give a more blue hue and look as opposed to mirror light more natural color. I had my mirrors fold during remote lock and light projected onto door, kinda defeated the purpose.Anyone else get these?
If so, what do you think? Like 'em or maybe a bit over the top?
Easy enough to swap out. When I get bored I can go back to factory. These things are cheap and when you see them for a second or two getting in or out, they are ok. My opinion. They do provide a great light if thats whats needed.....a nickels worth.I bought the ones under the mirrors, I just don’t know if I like the way they hang down yet of not. Looks like another camera or small spotlight.
I’ve thinking about getting the ones for the door bottoms, then putting back the factory lights in the mirrors.
Love the setup. That reel specifically for washer hose? How long 50ft? What make/brand reel?
Thanks! This setup was something I had been eyeing for over 2 years, this being my 3rd pressure washer I decided to go big.Love the setup. That reel specifically for washer hose? How long 50ft? What make/brand reel?
Awesome, thanks.Thanks! This setup was something I had been eyeing for over 2 years, this being my 3rd pressure washer I decided to go big.
It's a Cox 3/8th hose reel 100ft
100 Series | Coxreels
The hose is a cobrajet 50ft.
That is the best name ever! For a hose, lolThe hose is a cobrajet 50ft.
