Ticking Noise on 4BW
sethsquire
Nassau County, New York
CT4-V Blackwing
I'm getting what I can only describe as a faint rapid ticking noise in my 4. It sounds like its coming from the dash area, but nothing I press or manipulate on the dash or door quiets it down. It will, however, quiet down when I initially press down on the clutch, and the ticking speed seems to vary with the engine speed.
Any ideas or insight, fellas?
I have same ticking. Only hear it at idle. Same thing as you. Open your hood and tell me if you thinks it's coming from the engine.
So it goes away when you initially press on the clutch, but then comes back when the clutch is fully depressed? Does it get louder with the windows down?
That is strange, I will check on my car tomorrow.
The high pressure fuel pump (HPFP) makes a ticking sound on these cars at idle. It's located at the rear of the driver's side cylinder head, close to the firewall. If this is the noise you're hearing, that's completely normal.
thank you!
Thanks. That's kind of annoying that they would situate it where it would transmit a ticking noise to the interior. Sounds like its rattling the dash inside
It's covered with all sorts of sound deadening material. If it really bothers you, just order some of our downpipes. ;)
Is it supposed to make the sound off idle? I'm pretty sure it makes it when driving at low revs...
The HPFP always makes a ticking sound. It's just most evident at idle.
Update: This noise is really pissing me off so I'm taking it to the dealer to get looked at. Fully anticipating a run-around. Smh
