d0wnShifT
Has anyone gone through the trouble of installing catch can on these motors yet?  Are there any kits available?  I'm looking to do this and try to prevent the issues associated with DI engines.
I’m pretty sure there’s already one from the factory on them, rather than hold the oil it recirculates it back to the engineHas anyone gone through the trouble of installing catch can on these motors yet? Are there any kits available? I'm looking to do this and try to prevent the issues associated with DI engines.
Might Mouse made a catch can kit on the V3 LT4 for the PCV. If it hasnt changed on the BW LT4, the PCV is piped directly inside the blower, between the TB and the rotary screws. So if you have oil getting in thru there, you'd be getting oil into the blower, potentially oil soak the intercooler bricks and sucked into the engine.I’m pretty sure there’s already one from the factory on them, rather than hold the oil it recirculates it back to the engine
				 www.mightymousesolutions.com
				Between what @Mirza Grebovic said about this and @WONT TAP liking it I would say it's not needed, but i'm no expert............I’m pretty sure there’s already one from the factory on them, rather than hold the oil it recirculates it back to the engine
If I’m not mistaken, Tap Out @WONT TAP has one available.Has anyone gone through the trouble of installing catch can on these motors yet? Are there any kits available? I'm looking to do this and try to prevent the issues associated with DI engines.
We agree that the factory PCV/catch can system works completely fine on LF4 engines. However, this gets removed with some aftermarket intake systems. So the catch can system we offer is designed to replace the factory PCV/catch can system for LF4 engines with aftermarket intake kits.If I’m not mistaken, Tap Out @WONT TAP has one available.
L"T"4 is the subject.
Thanks for the info, but what are your thoughts for the LT4 engine on the CT5VBW?We agree that the factory PCV/catch can system works completely fine on LF4 engines. However, this gets removed with some aftermarket intake systems. So the catch can system we offer is designed to replace the factory PCV/catch can system for LF4 engines with aftermarket intake kits.
				 youtube.com
					youtube.com
				I'm sorry, is thisI've been looking into this as well, and it appears the LT4 in the BW does have an OEM air oil separator. I think the drain back to the pan is what tipped this into production. A serviceable collector that had to be emptied regularly would have never worked for a typical owner. The link below is a LT4 crate motor (and possible dry sump?) but it does discuss the separator and the drain routing.
✂️ Air oil separator
44 seconds · Clipped by Jon Bawden · Original video "LT4 Unboxing" by WranglerJKLSyoutube.com
The kicker with that air separator is that it pulls the vapors off the lines that comes off th valve covers (goes to the black capped ports in his video). The red port goes to the intake tract before the TB.I've been looking into this as well, and it appears the LT4 in the BW does have an OEM air oil separator. I think the drain back to the pan is what tipped this into production. A serviceable collector that had to be emptied regularly would have never worked for a typical owner. The link below is a LT4 crate motor (and possible dry sump?) but it does discuss the separator and the drain routing.
