First 2022 Ct4-v blackwing with the factory mounted rear view camera.
loudmofo
warwick ri
2022 CT4-V BLACKWING
So today i decided to see if i could install the rear view mirror kit from the Ats or the Camaro with the roof shark fin camera.
install took about 2 hours start to finish and required dropping down the headliner and removing the shark fin ,came out great i think not a bad days work if you ask. mine should of came this way from factory.
Very nice work!
Love the idea, but not having the antenna body-matched is a deal breaker for me.
The antenna cover is held on with 8 torx screws and can easily be painted at your local painter.
Hey! Props to the shop owner for signing up for our site! Good customer support right there.
I, unfortunately, don't have a good local painter who would paint that for any less than ~$250-300 (which is too much, I know) so its still unfortunately not something I'm going to pull the trigger on yet, but maybe one day...
Any link to the install instructions? I have a black ct4 so should match pretty well
To me it's just not the same...
Unfortunately GM only sells the antenna camera in black at this time, I have tried to find painted ones thru the supply houses
Here is a PDF of the install in a ATS Sedan, everything should be 90% similar if not more.
I have a local painter who does all the custom work for Mancuso Harley Davidson here in Houston. He painted a silver one for me @ $100, whenever you are ready reach out to me and we can try and get one done for you
Perhaps, I'm missing the obvious but, what's the benefit of this? All that I can see is that the rear view is in the mirror as opposed to being in the center screen. 🤷‍♂️
