There's a multi-billion dollar industry's worth of evidence that you're wrong, not to mention having seen it with my own eyes on a dyno.Modern engines control torque output to predetermined maximum values. Changing these maximum values requires modifying calibration. So installing parts without modifying calibration only increases potential (if even that) of the car to make more power/torque, but not actually do so.
My personal experience with an aftermarket exhaust, Corsa but ultimately less restriction is less restriction so I would expect the same performance impact, is that there certainly could be more lower mid-range power but there is nothing more up top. No reason not to believe the AWE dyno. Trap speed at the end of long straights is exactly the same as stock. It does feel like there's even more of a drop off on top end i.e. the mid-range is stronger, but I know my butt dyno isn't that sensitive to notice a 3% difference.I'm over my head here, but Tapout has discussed these new systems and this thread has some good info Tapout CT4-V Blackwing Carbon Fiber Intake Test Results
As I understand it, the cars do control the power output, but that is estimated based on sensor information, not a direct measurement. So you can reprogram the computer (Global B reprogramming), spoof the sensors electronically (JB4 add-on), or change the physical characteristics at the point of the sensor (Tapout's intake lid with larger MAF tubes). I would guess that a less restrictive exhaust could affect power since there is no sensor there outside of the oxygen sensors that are likely more concerned with gases and temperatures, not flow. I'm sure that some changes to systems can have at least a little effect within the variability of the programming. Or I'm completely wrong and probably offered nothing of use to the discussion...
What in the world… no. Just, no.Modern engines control torque output to predetermined maximum values. Changing these maximum values requires modifying calibration. So installing parts without modifying calibration only increases potential (if even that) of the car to make more power/torque, but not actually do so.
Funny how you can just change out the air box lid and get 50-70hp to the wheels.Modern engines control torque output to predetermined maximum values. Changing these maximum values requires modifying calibration. So installing parts without modifying calibration only increases potential (if even that) of the car to make more power/torque, but not actually do so.
www.tapouttuning.com
This airbox is spoofing the ECU. The ECU doesn't know that its producing more torque. The torque is calculated based on the inputs and when the inputs are spoofed, the ECU still thinks its produces its preset max. If it was to know the real numbers, it would dial down the boost/timing to limit the max. JB4 operates on the the same concept.Funny how you can just change out the air box lid and get 50-70hp to the wheels.
Tapout Tuning CT4-V Blackwing Carbon Fiber Airbox Lid - Tapout Tuning
I have to say it works pretty well. So well I'm not thinking to do anything more - power wise - for a while (if ever)....though I'd love to tune it further at some point. The extra punch is undeniable when you push it....very nice to have....otherwise seamless and runs just as smooth as stock.This airbox is spoofing the ECU. The ECU doesn't know that its producing more torque. The torque is calculated based on the inputs and when the inputs are spoofed, the ECU still thinks its produces its preset max. If it was to know the real numbers, it would dial down the boost/timing to limit the max. JB4 operates on the the same concept.
I will buy a used one when I see one for sale. Will do until I am closer to warranty expiration and I tune the thing. I know its not undetectable if they go looking to deny coverage if something comes up, but nevertheless.I have to say it works pretty well. So well I'm not thinking to do anything more - power wise - for a while (if ever)....though I'd love to tune it further at some point. The extra punch is undeniable when you push it....very nice to have....otherwise seamless and runs just as smooth as stock.
I spent a few hours in traffic on the interstate yesterday and the extra punch came in real handy when getting through some tight (otherwise slower than I would like to be going) situations...
Did you use the OEM tube size or oversized?I have to say it works pretty well. So well I'm not thinking to do anything more - power wise - for a while (if ever)....though I'd love to tune it further at some point. The extra punch is undeniable when you push it....very nice to have....otherwise seamless and runs just as smooth as stock.
Oversized. I've only had 2 CELS with it - both tied to quick re-starts after stopping in somewhat cold & damp weather. Cleared one myself and the other went away on its own pretty quickly.Did you use the OEM tube size or oversized?
I'll take the lid if you happen to change your mind.Not more than 4hrs after I typed my response above, I got a used intake lid with oversized tubs and a jb4 off facebook. Will stay with the lid until I find the time to regap plugs for the jb4. Not a fan of ECU spoofing like that instead of proper tuning, but it seems like people are not having issues with it.
Sorry, derailed the thread. Great exhaust AWE!
...Sorry, derailed the thread. Great exhaust AWE!
Any sound clips of the switchpath with tapout's catted downpipes?
In regards to the switch path set up, which sounds better? C8 Z06 or ct5 black wing?
I just got through listening to your YouTube videos for both vehicles. C8 Z06 sounds better, hands down. I guess the supercharger muffles the noise a bit on the Black Wing.Totally dealer’s choice. Sound is such a personal decision.. what sings to one driver might not hit the same for another. The C8 Z06 delivers a high-strung, exotic tone that screams precision. Meanwhile, the CT4-V Blackwing brings that deep, rumbling growl with punchy decel crackles that feel raw.
It really comes down to what kind of soundtrack you want behind the wheel: sharp and race-bred, or rich and aggressive. Either way, you’re in good territory.
