Engine Break In - 500 mi or 1500 mi
It's interesting that GM doesn't have this listed. I wonder if this is similar to the differential fluid and track use. The manual talks about changing at 1500 based on track usage, not street usage for the rear differential. TREMEC might recommend 1500 thinking that people could be pushing these transmissions hard. Does anyone that doesn't track the car change the transmission fluid that early?
My last 6MT, I changed every 30,000 miles without issues.
If the 1,500 mile break-in is more for the rear diff than the LT4, I think I'm going to prioritize optimal operating parameters for the glorious V8 over all else. Rear diff be dammed! 😉
I have learned that there are far and few "investment" vehicles out there. You need to be a multi-millionaire with more money than brains . The only cars that I have seen ,lately, (last 20 years) has been the Ford GT 40's. I wanted to buy one in 2005 when they were $150,000 and I figured that it was way too much money and passed. Now , they go for over $300,000. On the other hand, if you had invested $150k in the proper markets, you could potentially have even more money. Usually the rich guy buys at top dollar and as soon as he drives off the lot he has lost 20% in value. I have my Dad's 1967 Cadillac convertible. He paid $5700 for it. I have it insured for $40k. I have probably lost count on how much I have spent over the last 45 years keeping it in beautiful shape. It has its issues, but it is a driver , not a hangar queen.
It seems that only GM is concerned with overfill. But Tremec is not. In the other thread I added a link to a TSB for earlier corvettes I believe which started the whole under fill. I think gm was seeing fluid leaks thru the vent under high temps and that was their best of fixing it.
It appears to be an issue with ATF (not higher viscosity like the HP-MTF) as it expands as it heats up and blows out the vent. It's fine for the transmission, but who wants a mess under their car.
I think I going to try straight Redline MTL. It sits right between OEM and HP-MTF. This is one of these situations where I don't want my lube to be too slippery when things really heat up here in Arizona in the summer. - I prefer a crisper feel, even if I have to force it a little harder, over too sloppy. I've seen my trans temp get to 200F in normal city driving.
Given that you are in AZ - thicker fluid might work for you ok. In colder climates, Dexron III (GM adds some additives to their DexIII M/T fluid) is best choice, as it makes Tremec usable in the cold. I am a big fan of BMW MTL 4 - it works great in all climates. But not appropriate for a Tremec application.
Here is ATSV TSB which started the whole underfill thing. Prior to that GM did not care about underfilling the Dex3 filled Tremecs
It looks like the vent hole is/was working as intended.
I believe the main purpose to prevent a pressure buildup. On my Jeep I have vent hoses on my axles and yes they can eject gear oil, but only at first after a fluid change.
For what it's worth, my M4 was 1,200 miles for engine and diffs. Think I'll do the same on my 5BW.
1200 is standard BMW break in fluid changes which I think is very reasonable. I would change Diff, M/T and oil at the same time.
I had a manual CTS-V wagon and it went through 3 diffs due to howling. The first had a lot of highway miles during delivery. The next two were strictly by the book. Having done it every which way, I'm convinced it just comes down to luck of the draw. Get a bad diff, have a bad experience.
