AC2024
Yes, for sure! I am in a little bit of a challenging period of life regarding free time (2 year old, 6 year old, wife and I both work relatively demanding jobs) so track time will hopefully increase.... some day lol.
I've only tracked my C6 Z06 a few times, I have -0.9° camber and 1/16" total toe in the front, -0.5° and 1/16" in the rear. This is with the pilot sport PS2 (run flats) and I get pretty even tire wear.CT5 not 4, but I have mine permanently set up 1.7 in front and 1.5 in rear. It's equally non optimal for both street and track
But it's my daily so I don't want to run street alignment the few days a year that I'm on track, nor do I want to have the harsh(er) ride or tire destroying track alignment on my commute
OK, so the wheel didn't get bent. That doesn't change the fact that we are not looking at a wear issue. There is a significant impact mark on the wheel in your photo. There is a huge chuck of rubber missing from the inner sidewall exactly at the impact mark on the wheel in your photo. There are stress cracks visible on the inner sidewall at the impact mark in your photo. We see exposed wire right at the impact mark, but as we look down the tire, around the 4:30 position the exposed wire stops and cord is exposed. As we continue down to the bottom of the tire (6:00 position) the exposed cord is gone and we are back to full rubber. Looking upward from the exposed wire, by the 3:00 position we are back to cord.Incorrect @Kawman. I just had the tires replaced, they found no wheel damage at all. The barrel had small rock chips but nothing out of the ordinary. I kept that tire and will bring it to Cadillac when I get my alignment to see if this wear on the inside is normal or excessive.
