Dashboard Data
DonD
Central TX
2023 CT4-V Blackwing
I have a 2023 CTV-4 Blackwing. Car's great, really enjoy it.
Recently it had everything I like displayed on the dashboard, tire pressures, what gear I'm in, temperatures, all sorts of things. Then it's gone and all I have are a very small number of items.
Can anyone help me find how to get the extensive data input? Thanks
This is the control schernov is talking about:
You are probably in a different mode like Tour or Ice/Snow which doesn't have all the info panels on the left. You probably want to get back to "My Mode" or "V mode." Getting back to V mode is easy- mash that V button on the steering wheel. Otherwise use that switch above to get back to My Mode.
Thanks, I'm well aware of that control, guess I didn't ask the right question.
Well if you know you're in one of the modes with all the tiles then you may have enabled the 'simplify' or 'stealth' modes. Try turning those off.
You might have accidentally hit the stealth mode button - check your infotainment settings and look for a "stealth" or "minimize display" option to turn off.
Well, DUH here. The solution was as simple as switching to Sport mode. All the desired readouts popped right up. Thanks to all who responded.
Most of the cars I've owned in the past didn't provide access to more than the most basic info like remaining gas level and a general idea of temperature.
I've gotten spoiled by the availability of so much more.
