CT5-V Blackwing: Slight Yaw/Rotation under hard throttle
Also experienced the rear end float recently. 3rd gear, onramp on to highway, not WOT but moderate throttle input and the rear end was dancing around a bit.
Any other feedback from folks who either ordered the SPL arms and/or had an alignment done?
Have we ruled out the eLSD being a contributor to this feeling?
I installed the SPL toe arms and had my car aligned. That seemed to solve the problem. Before that, it was getting all crazy wonky under hard acceleration (in a straight line) in 3rd and 4th gear.
I do notice that if you have the suspension set to TOUR/SOFT, the car is a little more darty because the soft suspension setting allows for a lot of weight transfer to the rear under hard acceleration, taking traction away from the front wheels. Setting the suspension to 50% firm seems to solve that issue...
Ok I am ordering those tonight! It can't hurt, right?
My 4BW does this as well. Does someone make a similar piece for the 4?
Recently posted about this issue myself; however, I thought it was simply a tire issue: New PS4S tires - How long before they have some bite?
Reading through this thread, now I am not so sure. :unsure:
Short story – I was doing 65 on the freeway, lightly tapped on the throttle to go around someone, rear end breaks loose and goes side-to-side momentarily. Complete loss of control & traction. 😳
Unlike some who have posted here, I was not WOT... just lightly tapped the throttle. Scary.
The reason I thought it was the tires is because I only have around 1.2K on the car now, about 900 miles at the time of the "incident."
FYI, I have a 2026 5BW with the Precision Package (upgraded toe arms/links).
Also, here is my current alignment, performed by a local race shop for "aggressive street" use.
Check the rear toe. You want around 3mm toe in on each side. I had originally messed up my rear toe and had toe out in the rear. You could feel the back end moving around under heavy throttle.
How do you translate mm into degrees? From what I have come up with, 1mm = .8 degrees, so are you saying I should have 2.4 degrees of toe in each rear tire?!?
The answer there is the solid bushings from the ZL1 1LE.
Which bushings exactly? P/N?
I had the same concerning feeling from day 1. I have tracked two other Blackwing 5s and it is not a characteristic of the vehicle. After getting home from Spring Mountain, I took my car directly to the dealer and the rear toe was "way off". Problem is solved, it feels so much safer!
Can you post your alignment specs please?
WANTED TO BRING THIS THREAD BACK UP...
After 10,000 miles, my CT5V is experiencing severe rear end wiggle when you jump on the throttle at higher speeds in 3rd and 4th gear.
There have been pretty significant discussions on this issue on the Blackwing Facebook Group and people have tracked it down to a couple of issues:
- Wheel alignment: Evidently the rear wheel alignment can fall out of spec and cause this issue
- Rear Toe Links: The reason the wheel alignment gets out of spec is due to the stock toe links not being strong enough.
In cross-discussions with the ZL1 Camaro guys, the Facebook posters found they were having identical issues with rear-end squirrelyness, and they had replaces their toe links with the SPL versions and it corrected the issue. One of the CT5V guys replaced his toe links and reported the car is much more solid now and the rear end doesn't kick to the side when he goes WOT at speed.
I attached a screenshot of his post which shows the stock toe arms and the SPL toe arm links side-by side.
The part they are recommending is: SPL Parts Toe Arms with Eccentric Lockout (Rear) - Chevrolet Camaro 2016+ / Cadillac CT5 Blackwing 2022+
Part Number: SPL-RTAEL-CAM6
link to the part is below:
Here's what it says about those toe arms: "The stock eccentric bolts that allow for small toe adjustments tend to slip under high cornering loads, causing changes to the rear alignment. SPL Parts Eccentric Lockout (EL) kit eliminate the stock eccentric bolts to keep your rear alignment where you set it. SPL lockout plates are CNC machined from 6061-T6 Billet Aluminum and supplied with Zinc plated grade 10.9 hardware for absolutely zero-slip."
Please let me know your thoughts.
Curious how/if this applies to me, since I have the Precision Pack.
You guys must be on the track, because I can't imagine doing any kind of WOT in those higher gears, that's mandatory jail time around here!
OK, yeah, if you get caught, if they can catch you, yeah, I get it. :)
For me, it was a light tap on the throttle that caused the issue.
I'm came to my 5BW from a 2017 m6 ZL1 (not the 1LE). I never noticed the rear-end wiggle under hard acceleration with the stock Goodyear tires that came on the ZL1. It was only after I swapped out the Goodyears for the PS4Ss. I thought maybe it was the softer sidewall of the 4S that contributed to the backend moving around. I also noticed that the rear-end movement seemed to get worse as the 4Ss aged.
The 4Ss are superior to the Goodyears in the rain and cold but I'm not convinced they're the ideal performance tire for the ZL1 and 5BW. The softer sidewall might be fine on the lighter Corvette but on a heavier car like the ZL1 and 5BW there might be too much flex.
I have a hard time believing that the PS4S has a soft sidewall, especially with XL load ratings. Where are you getting your info, or why do you say this?
Interesting, may have to try this.
Anyone here have any suggestions?
Before I put PS4Ss on my 2017 ZL1, I read a lot of reviews noting that the PS4S isn’t really ideal for track use. The tire uses multi-compound construction, and the sidewalls are tuned more for comfort and compliance than maximum lateral rigidity. Essentially, it’s a compromise for everyday drivability at the expense of sustained track performance. Factor in the 4,000+ lb weight of the ZL1 or 5BW, and you can see why you might experience more sidewall flex compared to a Cup 2 or Goodyear Eagle F1 SuperCar tire.
this could explain the feeling I get when applying, even part throttle no where near 50%, that the back end is "swaying" a bit side to side. The tires are not losing traction and it might not be the ediff doing it's thing - could be the side walls flexing a bit as it all (power, ediff, traction, tires, suspension) sorts out under throttle?
I ordered the SPL arms tonight. This is a common and very worthwhile upgrade for modern bmws, which the 5BW architecture is the same strut front multi link (5-link) rear.
I was having all of the same issues before. Every time getting on the highway in about 2nd or 3rd gear, mash the pedal and the rear end would dance side to side as I accelerated. Based on this thread, I took it to an alignment shop that focuses on track cars and the problem is all but gone. My factory setting was 1/16” toe out in the rear which was causing the sway. He set it up for 1/16” toe in and the problem has gone away. It almost seemed like the factory put the correct 1/16” number but set it toe out instead of toe in. I also felt my steering at really high speeds was on a knife edge and the front camber was way off from factory too.
Interesting. A lot are reporting toe arms fixes the issue, but it could be just an alignment.
Everyone should be getting an alignment after the toe arms which might be making people think the toe arms are actually the fix?
I'll preface this with the statement that I am familiar with higher horsepower cars having owned a C6 ZR1 for 12 years now, the last two years modified to power levels significantly above my 5BW and I've tracked my cars for many years.
So, I've had my 5BW over 14 months now with about 7k miles on her. Love her to death and it's an amazing car. Only minor issue I've had is how the back end gets a little squirrelly under heavy throttle in lower gears, especially with this cooler weather we've been having in Texas.
What I mean is the back end walks around a bit under hard throttle. Could be slight slopes and/or crowns in the roads, but car seems to rotate a bit back and forth under power more than my ZR1.
Is it chassis/suspension geometry set-up or something odd the e-diff is doing? Is it the relatively smaller 305 tires? For example yesterday, I turned traction control off as I U-turned. Then when the car was straight, I nailed it in first, it spun up hard and I shifted to second, tires spun up again and car started to rotate a bit while I'm basically doing 60mph at this point. I lift a bit to regain control and car does a small "tank slapper" and snaps back into line and all is good. It's a little disconcerting as the car doesn't always want to stay straight when spinning.
I'm not saying this is a major issue, but I'd like for it be a little more stable under hard throttle when the tires are spinning. Any way to adjust e-diff or any other setting to try to take this down a bit? Or is it just the way this car is? If so, I'm not that stressed about it, but it would be nice if it hooked better in 1st and 2nd. :D
I'm noticing the same thing on my 4BW
