No lift shift
CaliBW
Upland
2026 CTV-4 BW
As a new BW4 owner can anyone give me user knowledge of how NLS goes. I presume I can't even try until 500 miles when the ECU changes engine parameters. I presume ARM must be on. thanks in advance for any insights.
I'm assuming the BW4 are the same as the BW5s, but as long as you are above 5k RPM and 80%+ throttle, it'll activate. Should hear an exhaust burble if done correctly.
Logic is fairly simple, keep throttle pinned and engage the clutch, shift and lift off clutch.
