BlueBird
I need some advice from you Blackwing master driver's out there.
Okay, so the Blackwing is the first manual that I've owned. Ever. I'm not bad at driving it like a "grandpa", or maybe like an "irritable commuter", but I suck at using this thing the right way.
Launching for 0-60? Lord. I can't get off the clutch fast enough and the car just spins the tires, quickly bouncing off redline and forcing me to shift to second while looking for traction.
No lift shift? How the @#&% does that work?! I could swear that I'm doing it correctly, but I only get it right in one out of 5 shifts. Foot all the way to the floor, shift over 5k rpm with foot still on the floor, but somehow I still wind up at the redline. Maybe I'm ever so slightly releasing a miniscule bit of pressure from the accelerator and it's cancelling the nls?
I'm heading to the V Academy next month but I may blow up my car before then.
How are you guys pulling off your 0-60 runs? Do you find yourselves with no traction? Maybe it'sy clutchwork? I watched a YouTuber pull an under 4 second 0-60 with a manual and he had zero drama. Meanwhile I'm fishtailing all over and getting 7 seconds.
What cancels nls? Is it working for you all? Should I even bother with it/what's the downside to not using it?
I feel bad for my car with me trashing it so bad all the time. Help me use it the right way. Advice?
