Hi all,
I just installed the Gigs TB on my 4v BW. As always, the hardest parts were getting plastic pieces to cooperate -- I thought bolts and that sort of stuff were easy to access in the engine bay. Pleasantly surprised!
I read through DesertRJ's thread on his installation experience, and am having the same issue with a CEL and reduced boost pressure (currently limited to 6lbs). I checked all the vacuum lines and connections suggested in that thread and so far, I've only been able to get rid of the "Reduced Acceleration Drive Carefully" message on startup. The CEL is still on and boost is still limited.
I don't have a scanner I can clear the CEL with at the moment, but my question is if things are OK (it's been driving just fine), will the CEL eventually clear after a few drive cycles? If I disconnect the neg terminal of the battery and leave it for a few hours will it clear?
And if it clears, will the ECU give me my boost back???
Thanks all for any ideas/comments/observations/buffoonery you offer!
***Important Edit***: as you'll see below, this is relevant. The first time I started my car (after following the instructions to turn on but not start the engine and slowly depress/release the accelerator x3), I had forgotten to plug in the Q40B Turbocharger Bypass Valve Solenoid - Bank 2.
