Driver's Side Rear O2 sensor extension
Souperman
New Member
Hudson Valley NY
2023 Cadillac CT5-V Blackwing 6M
Wrapping up my header install and getting everything buttoned up. The last bit I'm fighting with is the driver's side rear O2 sensor.
The passenger side didn't need an extension at all so I figured the drivers side would be more of the same. But that sensor on the engine harness is more or less behind the supercharger, and the wire coming off the O2 sensor is so far back, I either got them mixed up when I installed them or I'm doing something wrong here.
Attached below is the plug end coming out of the O2 sensor. Did I maybe accidentally get them mixed up?
The one in the picture looks to be the O2 sensor that plugs into the sensor located in the cat or the rear most sensors. Here is a screen shot of the instructions for the Kooks headers. By looking at it, I'm guessing the extension is not needed for the passenger side rear, but should be used for the drivers side. Hopefully that helps.
